Restoration of BMW E30 318is for Rallyes and Trackdays
  • MagicMiura
    • Jun 2015
    • 21
    Hi, this is my BMW E30 318is for Rallyes and trackdays. Originally I will go to the racetrack for have the feeling of the car.
    A lot of pieces to change.
    Paint job.
    Little sponsors.
    Ignition and start:
    Temperature sensors for the gearbox and the differential:
    F.I.A Papers:
    Brake coolers.
    Gearbox, Diff gauges and fuse box.
    Hydraulic handbrake:
    Stickers from the sponsor:
    Oil catch can:
    More pictures and info coming...
  • ccsdo5
    • Mar 2013
    • 708
    cool, more info on your hydraulic hand break please! Are you running dual calipers?
    -Dee
    5-lugged turbo 318is Barn car
    IG: @deebelmont
    • MagicMiura
      • Jun 2015
      • 21
      No. I only mount in serie the next components. In order. Stock brake master cylinder to the rear calipers, brake bias adjuster, hydraulic handbrake and I use the stock Tee. Simple and effective. You have to choose the correct master cylinder for the handbrake. http://www.rderacing.com/images/KIT-FRE-ECO.jpg
      Probably with dual calipers you don´t have the interferences between the pedal and the handbrake if you push them at the same time. Better feeling too.
      The reason why I mount this is because I can adjust the brake bias, Front to rear and I don´t have to mount an extra calipers.
      Greetings
      • TobyB
        • 5287
        You will find the diff gets warm. The gearbox will stay cool.
        t
        • MagicMiura
          • Jun 2015
          • 21
          t
          If the differential go too hot , I will mount an oil cooler.
          • MagicMiura
            • Jun 2015
            • 21
            Fuel pump and pre filter monted inside the boot.
            Playing with nylon
            Sparco seats and Lico belts:
            Just for the race track.
            When I bought the car:
            Rally lights:
            • TobyB
              • 5287
              Cheap way to cool the diff is the finned cover from a z3.
              Yes, it's $200, but cheaper and easier than plumbing...
              You may find you do not need to- you are wise to measure first, fix if need be.
              t
              • MagicMiura
                • Jun 2015
                • 21
                t
                Thanks for the info.
                • MagicMiura
                  • Jun 2015
                  • 21
                  Another 1.8L 16v 318is engine for pieces:
                  Some laps on the race track with my other BMW E30 318i:
                  Enjoying the views of Mallorca:
                  • MagicMiura
                    • Jun 2015
                    • 21
                    New Sponsors
                    Tow:
                    • MagicMiura
                      • Jun 2015
                      • 21
                      • MagicMiura
                        • Jun 2015
                        • 21
                        Ready for the track.
                        • MagicMiura
                          • Jun 2015
                          • 21
                          First video:
                          • MagicMiura
                            • Jun 2015
                            • 21
                            • Sirdaft1
                              • Nov 2012
                              • 129
                              2007 Big Twin Turbo 335i + 1989 E30 Track Car
