Lime Rock Noise Restrictions
  • Axxe
    • Aug 2004
    • 3355
    Hey guys, we are racing at Lime Rock next month and are wondering what you all are doing to be compliant with the noise rules. We are running a bone stock M52 with an exhaust that goes dual back to the center support bearing before merging and going into a generic high flow muffler. Is this going to be quiet enough? What works on a 24v? Our car is hardly loud but it isn't silent either, wondering if we should stick a glasspack or something ahead of the muffler.
    Keep it slideways!!
  • JRKOUPE
    • Dec 2004
    • 3159
    how would we know if youll pass w/o knowing your db?..
    sounds like youll be fine..it aint a very aggressive set
    up
    I am there over 10x /yr..w/ a 2.5 inch set up...single....hi flow everything...24v
    alot of loud ish cars pass there..
    bring stuff just in case.....
    coke can..coffee can...muffler...etc
    • Axxe
      • Aug 2004
      • 3355
      up
      If I knew my db, wouldn't have to ask :P
      Just checking to see what other have ran that have been compliant. All we have is a single 2.5" high flow muffler, you mention high flow everything....what does that include? I have a feeling we are louder than that.
      Keep it slideways!!
      • z31maniac
        • 17566
        Bring an extra muffler and welder, cut and fix exhaust if you don't pass in practice?
        www.gutenparts.com
        • Axxe
          • Aug 2004
          • 3355
          No practice. First time we would know if we are over noise restrictions is a black flag. 4hrs Thursday, 8hrs, Friday and 4hrs Saturday. We will be bringing a MIG and some stock E36 M3 rear cans.
          Keep it slideways!!
          • TobyB
            • 5298
            I have an old Supertrapp with a lot (8? 10?) of discs that I carried when we ran really quiet (92 db) tracks.
            It stuck out the back a bit, but it took that car from 98- 99 down to 88.
            Also bring a bunch of elbows and bailing wire and small drill bits and stuff... and
            you can fake up a lot.
            t
            • z31maniac
              • 17566
              Turn downs are also good since it won't be pointing toward the mic.
              www.gutenparts.com
              • djjerme
                • 5082
                If you know which side of the track the listening station is on, you can use a turn down to aim the exhaust away from it. Janxy, but it works.
                2016 Ford Flex
                • TobyB
                  • 5298
                  Some of the plumbing hanging off the back of the rotary Maaaaazdas is legendary...
                  t
                  • Axxe
                    • Aug 2004
                    • 3355
                    We have a downturn already, and it seems like we have one of the quietest cars around, maybe just stuffing the downturn full of steel wool and clamping some chicken wire over it might do the trick. Going to try my phone at 50', it can only measure to 81db though, might have to pony up for a ~$25 db measuring instrument.
                    Keep it slideways!!
