I did a little searching, but found nothing. Best Base model....
  • Karlspackler
    • Jun 2006
    • 510
    What would be the best base model e30 to start with to build an Auto-x car?
    This will be prepared to run in my local Street Prepared class. I am not looking to be "the best" or very competitive; just out there to have fun.
    Things to discuss....
    Brakes
    Differential
    2 or 4 Door
    power? (In my case I will be swapping in a Black top sr20det I have laying around, so that will not matter so much)
    Weight? Which car is the lightest?
    Subframe?
    Cars W/O sunroof?
    Suspension Systems?
    etc etc.... You guys get the idea.
    Discuss
  • Scott314
    • Jan 2005
    • 287
    Brakes
    Differential
    2 or 4 Door
    Subframe?
    Cars W/O sunroof?
    Suspension Systems?
    Discuss
    I wasn't aware that engine swaps were legal for SP...
    My fast says: traction control is for the faint of heart :evil:
    • Karlspackler
      • Jun 2006
      • 510
      Oh sorry. Meant Prepared. We actually kinda just group the "engine swapped" cars together and call it prepared depending on the other modifications. There are very few (Less than 30 cars) that regularly auto x
      • german g
        • Feb 2006
        • 1608
        that engine is gonna throw off your wieght dist., more power, but heavier than an M20..
        90is, longtube headers/straight pipe/mark d 18# 93 0ctane chip/18# injectors/vogtland springs/bilst. sports
        :firehop:
        • Gus
          • Jan 2004
          • 285
          Sr20Det heavier than an m20?
          not quite...plus the weight distribution is far better, being a 4cylinder. think s14
          JUNGL3
          1990 "333i" Sport
          • oh2fly
            • 519
            I would look for a non-sunroof 318i stripper with no options, with hand crank windows. Then swap in a disc brake rear suspension with a lSD. My son did that and it weighs 2060 lbs. minus driver with an m42 in it. Your power to weight ratio will be even better. The surprise is getting the right springs in it. The lighter an e30 gets, the higher it sits and you need a REAL short spring in the back or go full coil-over setup. What's money when you are having fun, right?
            1988 Alpine white M3
            1985 Delphin gray 323i, "Junkyard Dog"
            • Karlspackler
              • Jun 2006
              • 510
              I will most likely be running either bimmerworld coilovers or Ground Control Coilovers.....
              I have about 1000.00 budgeted for coilovers
              • 2002maniac
                • 4260
                Brakes
                Differential
                2 or 4 Door
                Subframe?
                Cars W/O sunroof?
                Suspension Systems?
                early 318i without sunroof
                325 or 318is subframes front and back
                stock brakes with race pads
                As much power as you can get
                Go to GC or TCK for suspension
                Cut out fenders with the widest tires ever
                Sounds like you'll be in a Modified class. Good luck being competetive...
                • Teaguer
                  • Sep 2004
                  • 6167
                  318is is your friend .
                  • Karlspackler
                    • Jun 2006
                    • 510
                    Thanks for the info. I dont know if the last part was sarcasm but I take it as it. I do not plan on being that competetive in the auto-x nation wide, but locally... I will be.
                    The car will put out 225-230 whp on the Phase 1 of the build in a 2000lb car makes for a very fast and nimble car. With racing slicks and a tuned suspension I think that I can be competitive at the auto-x. Plus it will be a low 12's car.
                    Phase two includes a tune, injectors, and a gt2871r and 350 whp.....
                    You get the idea what that will be like.
                    • Karlspackler
                      • Jun 2006
                      • 510
                      Thank you, a 318i or is is what seems to be the concensus.
                      Difference in 84-87 or 88-91??????
                      Which has its advantages
                      • german g
                        • Feb 2006
                        • 1608
                        Find the wieghts, im pretty sure the nissan engine is heavier...I might be tinking about the skyline 6 cylinder though...
                        But, i wouldn't put a nissan engine in a bimmer though...But thats just me being a semi-purist..
                        :firehop:
                        • Karlspackler
                          • Jun 2006
                          • 510
                          I generally wouldnt either, I have one so why not though.
                          The sr20det is very light. All aluminum block....
                          I would say it is lighter than the m20
                          • german g
                            • Feb 2006
                            • 1608
                            cool, whats the hp of that engine..Theres a guy i know that just put a skyline engine in his 240....it sounds pretty damn quick.
                            :firehop:
                            • Rob
                              • 8166
                              i think like 220-230whp with basic mods right?
                              SOunds like it'd be a fun car, I'd definitely make it more of a all around street car than a dedicated Autocrosser though.
                              BEERTECH
