Rust on racecar?
  • brokecollegekid
    • Aug 2015
    • 158
    Rust on racecar?
    So I'm brand new to the whole E30 scene but I wanted to get into some track/autox and maybe SE30. I've got an 89 sedan with a little bit of cosmetic rust, nothing more than 2 inches in diameter. Frame rails are straight and not rusty at all. I was just wondering how strict are they on rust during tech inspections?
  • e30_302
    • Sep 2013
    • 453
    Hit it with some Rustoleum and move on.
    • e30s50dan
      • Nov 2008
      • 2076
      ^^ agreed,because racecar!
      NASA
      BMWCCA member
      PCA member 25yrs
      1991 318IS slick top
      1997 M3 sedan
      2001 325CI DD
      “whoever turns the wheel the least, wins"
      • djjerme
        • 5082
        ^^^This.
        A race car is a tool, like a shovel.
        If it really bothers you, find someone with a cheap wire feed, grab some scrap sheetmetal, weld it up and lay a thick coat of self etching primer and maybe some paint.
        2016 Ford Flex
        • brokecollegekid
          • Aug 2015
          • 158
          Alright thanks guys.
          • rcsoundn1
            • Nov 2012
            • 3361
            Free weight reduction
            • djjerme
              • 5082
              ..and if you race the car long enough, rust will be the least of your worries.
              2016 Ford Flex
              • brokecollegekid
                • Aug 2015
                • 158
                So when I go through tech inspection they won't be like, oh you have some rust you can't race. They just look at tires, cage, seats ect. and if that's all fine you're good to go.
                • djjerme
                  • 5082
                  If tech was worried about that sh*t, 95% of the chump cars (and good section of SCCA/NASA) would never make the track.
                  Now, if the floor looks like swiss cheese where the seat mounts, yes, they will probably have some words and might not let you out there.
                  The order of importance:
                  -driver competence
                  -driver safety
                  -other drivers safety
                  -turn workers safety
                  -fire risk
                  -what you had for dinner the night before
                  -numbers/class readable
                  -what your ideal mate looks like
                  -how your car looks.
                  get the picture now?
                  2016 Ford Flex
                  • TobyB
                    • 5243
                    Race long enough, the rust gets worn off.
                    True of the driver, too... eventually....
                    DO look carefully, though, because SOME rust always means SOME MORE rust in other
                    places, and if you've already found most of it, tech will be easier on you.
                    Like the rusted- away Y- pipe under the rusted- away cover plate
                    up under your right rear wheel that lets you dump fuel out there when you have
                    a full tank....
                    t
                    • djjerme
                      • 5082
                      Not that we EVER seen that on an E30.
                      2016 Ford Flex
                      • Cephas
                        • Apr 2012
                        • 878
                        Stupid question I'm sure, but curious: Can frame rail rust be properly repaired?
                        • M-technik-3
                          • 18946
                          We have raced our shitcan Lemons racer for the better part of 4 years and was rust when we started. Depreciation is done on it and if it makes a half of 2016 season we are retiring it in a blaze of glory.
                          • exhaust
                            • Jun 2015
                            • 411
                            My Lemons 325is has about 20% of the body missing from rust including a giant scar from the driver side door going back until about 2 feet from the end of the car.
                            The outside looks like hell but the cage is solid and the frame is healthy. Cosmetic doesn't really mean anything. I feel less bad when I hit stuff too
                            • QUKBMER
                              • 8178
                              Because ..........rust patina
