Went with 245/45/15 15x8 installed pics
  • Luis325
    • 3847
    Any ideas if they are too big for the 15x8 wheel for the e30?
    Its an Early model sedan with 24v swap track car.
    I have TR motorsports 15x8 wheels and im looking to buy some TOYO R888.
    Just wanted to have the widest r888 tire icould get.
    They come in 235/50/15 and 225/50/15.
    Also 245/45/15 is an option....
    For clearance i have a set of wide fender flares i can install. Just not shure if the tires are too tall/big.
    Thanks
    1986 "C2 2.7 Alpina" Sedan
    1987 325ic Black Vert
  • e30_302
    • Sep 2013
    • 453
    255 17's on all four here. 8.5" wheel up front 9.5" in the back.
    • lcoleman
      • Jan 2009
      • 331
      I'd go for 225/45/15. Depending on right height and offset, that will be pretty comfortable with stock bodywork. I have run the first-gen BFG Rivals as well as Hankook RS3s on 8" wheels and spece30 stuff with no issues. I'd guess r888s probably run a little wider, however.
      • Northern
        I like cupcakes & sh!tboxes
        • 5240
        I would stick to 205's or 225's on those wheels. I think Wh33lhop ran that exact setup for a while, pics should be fairly early in his build thread
        Edit: He ran 205 R888's on his 15x8 C1's, and 225 RS3's before that. They look about the same width in the pictures though.
        Originally posted by priapism
        Originally posted by shameson
        • ahrensNW
          • Mar 2015
          • 1716
          I have trm c1 on my car with 225 50 15. Either go 225 50 or 205 50.
          Hank Ahrens
          1984 Alpine Coupe
          1978 911sc
          • FredK
            • 14761
            Nando has run 235/50R15 R888s
            • amcp
              • 489
              I use 225-45-15 on 15x8 TRMs. There's a hairs worth of clearance on the front strut tubes but its worked out great.
              • Reub_e30
                • Apr 2016
                • 145
                R888s are much wider. The size you want would prob fit better on a 15x9. A 225/45/15 r888 can be compared a 245 almost
                Daily: 06 Chevy Colorado (wannabe racetruck)
                Drift/Track Car: 91 Bmw 318i 4dr
                • Luis325
                  • 3847
                  How about 245/45/15??? I have a set at the shop I could use. Anyone run this size?
                  • Emre
                    • Sep 2007
                    • 1228
                    Dedicated track tires or mixed weekend/track use?
                    In either case, I'd suggest another tire. R888 is the worst R-comp I've ever tried. Grip isn't that great and they wear funny. Unbelievably sensitive to setup and heat; you really need to baby them.
                    1987 Mercedes 190E 2.3-16: Vintage Racer
                    2010 BMW (E90) 335xi sedan: Grocery Getter
                    • JRKOUPE
                      • Dec 2004
                      • 3159
                      yup.....widely disliked by most......I loved my ra 1..not the fastest..but last 4 ever.
                      • Luis325
                        • 3847
                        Got a good deal from a friend who just got the Achilles Radial line here in PRon some ATK K-sport 245/45/15 track tires.
                        Going to give them a try.
                        They look good on the E30, lets see how they behave on the track...
                        • Luis325
                          • 3847
                          Meatyyyyy!
                          • Wh33lhop
                            • 11705
                            Whoa, crazy! Never heard of those before!
                            paint sucks
                            • Luis325
                              • 3847
                              Drove the car today and no rubbing anywhere.
                              All i have is a 5mm spacer up front.
                              Might get some 5mm for the rear too so it looks a bit better.
                              Really liked how it turned out. Feels good on the street.
