What wheel and offsets are you using? I'd like to try and stuff these in.
Anyone here try the 245/40/15 Maxis RC-1 or VR-1's?
Tags: None
Our experience with the RC-1's has been that they're not much faster than the same size 200tw Rival-S or RE71......but they wear like iron and you can actually run a full 20 minute session.
The VR-1's seem decent for a fun dual purpose tire but if lap times count you'll want to be on one of the above mentioned faster 200tw tires.-Brad
My E30: http://www.r3vlimited.com/board/show...50#post3916850Comment
So ive run these at two seperate hpdes now. Im running 15x8 trms with 225/45 rc1s. At firat i didnt like them. They didnt feel much grippier than the rivals i had. Wasnt sure what the deal was so i played with tire pressure etc. My car is light at around 2100 lbs. At the last session of the last event i was like to hell with it and dropped pressure down to 26/26. I was mixing it up with some tt3 guys and suddenly the grip was there and i was turning decent laps on em. I think i wasnt pushing them hard enoughand getting them hot enough. When i came in i immediately noticed they had gotten soft because they were finally sluffing like a slick. Anyway im gonna run em again for next event before i throw on my hohos.Comment
RC1 is similar to Nt01; its sidewall is soft and likes smoother inputs; you can actually miss-match them with nt01 they are close enough.
RE71r and RS4 will be roughly 1-1.5 seconds faster than both rc1 and nt01.OBD1 M54/M52TU swap as a M50b25
Compared to take off Continentals, to RR, to RE71R. They are ok and fun as they slide well and wear similar to granite. Also, the fact that they care so little for camber it would not be too bad of a choice for a DE tire for dual purpose cars with street-able alignment specs. It's a much different feel and car setup than NT01.Used to drive E30s.Comment
different feeling yes, lap times = same
wear rate = same
if car has non-adjustible dampers + you don't have an alignment rack @ the racetrack and are switching compounds between days; its good enough as same.
In a pinch I've even mix and matched them with nt01 and ran same or faster as all nt01 or all rc1 - front axle nt01 rear axle rc1; no slower than all 4 one or the other.OBD1 M54/M52TU swap as a M50b25
I've got them on my 15x10 Jongbloed wheels that I am selling. Haven't had a chance to really try out these tires, I used them for 1 session then it started to rain. FYI I am selling my wheels (I sold my car), PM me if you want to buy them!
sigpicComment
