Treehouse CAB vs. M3 CAB
  • squidrope
    • Dec 2012
    • 291
    I just ordered a set of the Treehouse CAB and noticed that the hole which holds the control arm is in the same location as stock. I also have a set of M3 CAB which are offset from the stock location. Does anyone know why Treehouse wouldn't have mimicked the M3 CAB offset? Since I have a machine shop I could build myself a set similar to the treehouse but with the M3 offset. What does the offset gain me?
  • mr2peak
    • 2388
    More Caster. You are trading low speed maneuverability for high-speed stability. Do you ride bikes? It's the same effect as changing the head tube angle.
    Drive it hard. Maintain it well.
    A Topless Memorandum
    • TobyB
      • 5298
      It also adds camber when the wheels are turned significantly.
      Bikes lean, cars do not, so the effect is different.
      I am surprised the Treehouse ones are in the stock location...
      t
      • berlow94
        • Jan 2013
        • 1063
        Treehouse only recently started making FCAB's on the stock location. In the past they only made them in the M3 offset. Now they offer them in both options. In the future, do more reading before you order.
        And yes, the reason is for more caster. (A slacker head angle)
        The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
        • noid
          • 1537
          +1
          I ran M3 offset Treehouses.
          1. Super sharp feel
          2. Super harsh on bad roads
          3. I would advise going/keeping with the stock location instead of M3 offset.
          Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
          Your resource to tools and tips: www.rtstools.com
