autox class
  • shootnjunky
    • Aug 2014
    • 506
    autox class
    ok, so I searched but didn't find any recent posts regarding this. so I will ask
    Have a 1989 325i with the following upgrades need to know class
    s52 swap w/tune
    UUC front and rear swaybar upgrades
    3.73 lsd
    ground control coilovers w/camber plates
    custom exhaust
    rx7 brakes
    stainless lines
    green stuff pads
    thinking this is some sort of modified class, but i'm not sure which one.
  • Bavarian3
    • 1230
    TBH it doesn't matter. If this is your first AutoX event, you can just sign up in novice in most groups that run them. Depending on what group you are running also varies the classification.
    • agent
      Vice Grand Pubaa
      • 7960
      The engine swap puts the car in SM, though I don't know if there's another classification beyond that for the suspension mods.
      Originally posted by kronus
      • Digitalwave
        is a poseur
        • 6287
        Probably street mod (SM) if you still have a full interior. What wheels and tires?
        RISING EDGE
        • Jean
          • 18228
          Yep - you'd be in SM class.
          When I autocross few years back, engine swap alone dictated SM class.
          • Sh3rpak!ng
            • Jan 2014
            • 2667
            A few years ago when I started autoxing my e30 I looked through the rule book out of curiosity to see where I'd be classed. IIRC the steering rack swap alone technically pushed me into SM. Unless things have changed, I don't think steering rack modifications/upgrades outside of what was available from the factory for the production run of the car are allowed until a fairly high class (SM?)
            That said, the motor swap throws all that out the window anyway. You're in SM
            Shadetree30
            • shootnjunky
              • Aug 2014
              • 506
              Thanks, there is one more run this coming sunday and I believe the car is in all working order so I will be able to run it.
