Kill Switch Advice
  • GThomas
    • Dec 2010
    • 869
    Kill Switch Advice
    Need some kill switch advice.
    Using this diagram.
    Is this the correct high current relay?
    https://www.amazon.com/…/B00DE3HY4K/...ved_title_6…
    And would the correct way to add another kill switch (one in drivers reach/one for corner worker) be to add another wire off the relay and splice the pin 27 DME wire again? Almost doubling up what I did the first time for another switch?
    Also any suggestions on switch brand and location?
    Thanks!
    1991 318is S52
    1987 325i Vert
    1991 325i
    2011 e70 X5
    Need Anything E30? -> http://www.gutenparts.com/
  • TobyB
    • 5296
    linky no worky.
    but no, you'd wire 2 switches in series, so either could break the loop
    powering the high current relay,
    and stop the car.
    I had to use a kill switch with a low- current secondary as well, to disable the alternator.
    t
