or you could do some seam welding........
betafoam
My 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.
Isn't there a new Ford or GM truck SUV that is currently advertized as being "filled" with foam? It should work to had strength, and keep sheetmetal from resonating. But if we remembers Ford's old Aerostar minvan, it had foam-filled rocker panels that rotted within a couple of years. That was a major blow for whatever company made those minivans.Brake harder. Go faster. No shit.
massivebrakes.com
what's the advantage? i'm still not seeing thisRecent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
Instagram.com/garageaholic
Youtube.com/garageaholic
how do you know which foam to use?
This any good?
http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumberLast edited by dgmorr; 03-21-2007, 06:05 AM.
Originally posted by dgmorr View Posthow do you know which foam to use?
This any good?
Actually, to answer your question seriously, I think what would be most desirable would be some memory foam. It might be a pain to install, but the gains would surely be worth it.
try here: http://www.memoryfoamfactory.com/
If you got your head outta your ass you would realize that the foam needed isn't your standard insulating foam.
With basic reading comprehension, it is possible to see that in the article posted, they suggest a Foamseal product. Although that might seem like a reasonable place to start looking for info, you were apparently oblivious to this.
Because you can't function on your own, I will give you a link that a regular person would have easily found. Whether you will be able to make anything out of this or not, I am not sure.
http://www.foamseal.org/automotive.htm
Originally posted by bimmerboy570 View Posti have heard this used in the early model nissan skylines to increse raginity(i think thats the word) but they used it to stiffin it even more after a roll cage was installed it also brings the weight distrabution closer to the ground
And putting foam in the frame rails is going to have a very minimal effect on the weight distributionSan Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
Originally posted by FJ40 View PostIf you got your head outta your ass you would realize that the foam needed isn't your standard insulating foam.
