Use Basketweaves or stick with heavier Borbet wheels
  • flypenfly
    • Feb 2007
    • 45
    This is all for track/auto-x use. I don't want to go Rcomps until I'm decent on good street tires.
    I need to decide what to do about wheels/tires pretty soon.
    Its been suggested to me that it would be better to replace the 16" borbet wheels with the extra set of 14" basketweaves I have. What's the weight difference? The borbet T is 21lbs, will it make a big difference changing back to the basketweaves? I think the 16" wheels are heavier but I can put down some more rubber.
    What should I do? Stick with the heavier Borbet wheels and get a bit more rubber or downsize to the lighter OEM 14" basketweaves and go with less rubber?
    I'll probably be picking up the Falken RT615 or the Yokohama ES100.
  • JRKOUPE
    • Dec 2004
    • 3159
    shoes
    ...........its no biggie. Depending on your power, 14's are fine. But youll get more sizes in 16's. I track on 15's..........
    • flypenfly
      • Feb 2007
      • 45
      Well I'd like to stick with the Borbets but not if it's not going to give me any benefit over the 14" and is actually a detriment.
      • JRKOUPE
        • Dec 2004
        • 3159
        wheels...
        ..what level are you?....nationally ranked etc?.........if not then use what you have...........on tight a/x tracks , 14 may feel more nimble........start w/ what you have........are you looking for that extra .4 seconds?......its all nuts and bolts......work on the nut behind the wheel.
        ES100 for hi po use?.......I hate em. Noisy and not hi po........
        • flypenfly
          • Feb 2007
          • 45
          Yeah, definitely beginner to intermediate, only been to a few auto-x. But since I'm buying tires anyway for two cars right now, might as well ask I thought.
          I'll probably be getting the basketweaves with the RT615 then in 195/60/14.
            I think the bottle caps are something a bit over 13lb each. That's a big difference in unsprung weight over the 21lb Borbet wheels. For track/autox use, a 15x7 wheel meant for Spec E30 (Team Dynamics, etc) is a good choice.
              • 34836
              switching back and forth between wheels, there's a pretty big difference between 15" euroweaves and 14" weaves. I'd definitely go with the lighter wheels.
              also you will get crushed if you use ES100s...
              • 92 mtechnic cabrio
                • 4907
                yeah, there's a HUGE difference between ES100s and azenis, that's like different ends of the spectrum!
                R.I.P 07/01/09 - 04/23/10 :(
                • flypenfly
                  • Feb 2007
                  • 45
                  Alright, staying away from the ES100.
                  What's the weight of the basketweave 14's or is that the bottlecapS?
                    • 34836
                    they are about the same. something like 14lbs.
