any1 here running the sparco harness bar? i cant get it to sit rite, it wants to sit in a U shape with the hoop sitting downwards, but i think it should be sitting with the hoop facing backwards...when i try to push it back, it get really tite, and already broke my A pillar panels...:-?
Sparco harness Bar install
Are you tightening it down before it is in place? I am assuming you are leaving it loose.:: PNW Crew ::
'87 325 4dr, '74 2002 -
mine looks like ^ rite now. i want to get the hoop higher though, but it already cracked up my Pillar covers just like yours... did the bottom of your support bars have like a triangle metal plate on it with one hole and a notch?IG: @Baye30
FRONT VALENCE IS ZENDER!!! STOP FILLING MY PM BOX PPL!!!Comment
I was going to ask the same thing. It seems to damage or require removal of the same parts... the seat, plastic B-pillar covers, etc...
And since you have fixed back seats, harnesses, and no rollover protection, you're toast in an accident that caves the roof in. Worse off then stock, IMO.Comment
I hate to burst your bubble (not really:)), but the structural strength of the human head and cervical vertebrae is less that that of a stock seat back in a roll over situation. So it likely won't matter in a roll over if you are in 4-5-6 point harnesses and a fixed back seat or in the stock seat with the cross-chest belt. If the roof collapses you'd best have jelly/jam in your back pockets as you'll be toast either way without a cage for crush protection.And since you have fixed back seats, harnesses, and no rollover protection, you're toast in an accident that caves the roof in. Worse off then stock, IMO.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
Not to mention the damn thing costs nearly as much as the VSR 4 pt.
What I was $399 + shipping for the bar, and $549 for the VSR 4 pt.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
Ehhh, with a stock 3 point belt your body will just move out of the way... (best case scenario, anyway)
If you are referring to using a 4/5/6 point, then yes, you are equally as screwed with or without the fixed back seat. If you have a harness, you should have rollover protection. That's what I was getting at. The use of a harness without rollover protection (AKA harness bar) is a bad idea IMO.Comment
The point of a harness bar and 4 or 5 point belt is to keep you behind the wheel as much to save your ass in a collision.
Roll over is a different story.Comment
Well if you are doing any high speed driving event, why would you put yourself in a position where if your car does roll over you are most likely dead?
I don't think the "point" of harness bars have anything to do with collisions. I think they allow you to use harnesses at low speed events such as autox's where the chance for rollover is low and the desire to hold yourself in place is high.
I don't think anyone has been saved with a harness bar and harness vs. a stock 3 p.t system.Comment
That's a good point... However.
The chance of a real roll and tumble at an auto X or cone slalom is pretty low.
In just a roll over on flat ground the lid usually holds up pretty well and in this case a harness will keep you from flying around (and possibly halfway out a window... Very ugly sight).
Me personally... I'm all for a full cage.Comment
