Slipstreams for track wheels
  • E30Driv3R
    • May 2004
    • 1169
    I am sure at least a few guys use these as track wheels. I searched but nothing really came up. I really just want them for a wider wheel to put beefier tires on them.
    I am thinking about 15x8 Slipstreams but not sure about the weight of them.
    Do you think that although the 16X8 weigh more they might be better since i can run a 225 Azenis on them as apposed to the stretched 205 which i would run on the 15?
    Any input would be appreciated.
    Dan Zickel
    1995 M3, 1991 318iS, 1987 325iS
  • backtrail69
    • Jul 2005
    • 4471
    My 16's are only like 15-16 lbs at most. They are pretty light. I run mine as street wheels, but they fit my 225s perfect with no spacers or hub rings.
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • markseven
      • Sep 2006
      • 5327
      I'm running 16x8 Slips with 205/50 Ecsta SPT's. Love the set up on road & track. Never AutoX'd so I can't speak to that.
      I Timothy 2:1-2
      • Jean
        • 18228
        What's the max rim width in STX, is it 7.5" or 8 ?
        • E30Driv3R
          • May 2004
          • 1169
          8''
          245 tires
          I thought the slipstreams were a little heavier than 15lbs... any way keep em comin guys i really need some track wheels
          Dan Zickel
          • joshh
            • Aug 2004
            • 6195
            Track or autocross?
            I'd run the RA1's if it's just for track days.
            "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
            ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
            • E30Driv3R
              • May 2004
              • 1169
              autoX this season track next
              Dan Zickel
              • markseven
                • Sep 2006
                • 5327
                The cool thing about Slips is they will clear any BBK.
                I Timothy 2:1-2
                • E30Driv3R
                  • May 2004
                  • 1169
                  good to know...
                  anyway what size? 15 or 16?if i was in DSP id go 15w/ some R Comp
                  But till then u think i should go 16? so i can run 225 azenis?
                  Dan Zickel
                  • Jean
                    • 18228
                    You can still run 16s in DSP also, or go big like Alex with 18x10s :)
                    • E30Driv3R
                      • May 2004
                      • 1169
                      I know that, but the only reason id go 16 is to run the wider azenis.
                      If i was running RComp id run 15s, because they are smaller, lighter, and i can get some WIDE hoosiers in 15, and cheaper lol
                      Dan Zickel
                      • fretburnr
                        • Jan 2005
                        • 1496
                        I'm looking to get a set of the 16x8 slips to run wider rubber than my 7" wheels.
                        the only azenis i can find in a 16" size is a 215/45-16 (same as my rs2s)... in order to go to a 225 it looks like you have to oversize at 50 profile.
                        am i looking in the wrong place?
                        Jay
                        • joshh
                          • Aug 2004
                          • 6195
                          Personally I'd do the 15's and R compounds.
                          • E30Driv3R
                            • May 2004
                            • 1169
                            Ya, if i was going to run R comps, id get 15.
                            Prolly next year ill go up to DSP, (Less cars and no WRXs)
                            I honestly thought that the 225 was a 40 series tire.... damn.... ill check around.
                            Dan Zickel
                            • speedblind
                              • 252
                              My 15x8 ET 20 slipstreams were 14.8 lbs. each, so 16s shouldn't be that much heavier.
