Going to gut my E30
  • JoeyJoeJ0
    • Sep 2006
    • 223
    #31
    Strip whatever you personally dont want in the car. I know exactly what your doing and my good friend is doing the same thing. right now there is nothing in his interior except a half cage, bucket seat, harness, and the dash. No a/c, no stereo equipment, no heater.
    • kendogg
      • Jul 2006
      • 348
      #32
      Originally posted by kishg
      you've done 2 HPDEs and you want to lighten the car? i would suggest you put the effort into a few more HPDEs. also, you asked posted here so you asked for opinions. no need to get defensive.
      Oh I plan on doing more HPDE's, don't you worry. I posted looking for information on what specifically I'm looking to do. I'm about this close from asking a moderator to delete this thread entirely, as I've gotten very, very little information pertaining to the original post, and plenty of OT comments/banter/bitching.
      • kendogg
        • Jul 2006
        • 348
        #33
        Originally posted by lance_entities
        Lightening the car would make them relatively "stiffer" for the weight than what they were before. So you'd be making it better off. [Springs for a 325i would be stiffer than similar springs for a 318is...]
        Charlie makes a solid point in that our pal bought a stripped-out E30 street/track car and getting it back to his desired condition is a PITA... but then again the PO removed wiring harnesses, etc.
        Do what you want, you're an adult, but consider the value in weight of removing some things that might be of value to a buyer.
        See, thats what I was thinking. I was under the assumption that later 318is aftermarket springs/struts were the same for 325's?? I know early model M10 318's were different, but my suspension came out of a '91 318is, sorry if I didn't specify.
        I'll retain most of the interior parts to be able to put it back to a daily drivable car when I do infact sell it. You people must think there is no place to sell an E30 outside of these forum walls/Spec E30 candidates (no offense intended towards you lance, you've actually been helpful).
        • ddavidv
          • 344
          #34
          Ken, I think you took my post for the spirit it was intended. Cool.
          Basically - I feel I'm getting close to the limits of the car, and since I can't quite afford to get a E36 and do what I want to it yet, I want to try to squeeze a little bit more performance out of this car for as little money as possible before I upgrade cars entirely.
          I was in your EXACT position with my last, pre-BMW car. I simply couldn't drive the thing any faster than it was. I could have done some of the things you talk about and made it marginally quicker, but I didn't. And I still had a hell of a time selling it for anything approaching a decent price. I'm just trying to push my 43 years of worldly experience down your youthful throat so you are ahead of the game when you do go for the faster car. ;)
          Yes, there is a world of market out there for E30s of most any description, but with as many guys looking for E30 donors as there are now it just is foolish (to me) to cut yourself out of that market.
          • Mastrcruse
            • Sep 2005
            • 5340
            #35
            Okay here is the list thus far:
            trunk tar
            carpet
            rear sears
            rear parcel shelf
            A/B/C pillar trim
            headliner
            door panels
            center console
            Originally posted by Mike B.
            Glove box
            Heater core
            Exterior sound deadening in the transmission tunnel
            Sunroof componants
            1-piece racing seats
            Next comes lexan windows, FG bumpers and FG hood/decklid for another drop in weight.
            Originally posted by jlevie
            Headliner
            Entire sunroof (used the sunroof panel to fill the hole)
            Carpet
            Glovebox
            Door panels and other trim (replaced front panels with AL sheet (protection from flying glass))
            Cruise control, module, and wiring
            Radio, speakers, amp, and associated wiring
            AC compressor, condenser, aux fan, dryer & lines
            PS pump
            Replaced engine driven fan with 16" 2500cfm electric fan
            Trunk lining and tool kit
            Spare
            All sound deadening in the cabin and trunk
            Underhood lining
            Umm..theres not much more you can do. Thats basically all the heavy stuff on the car but I can add some. You can start doing fiber glass hoods/fenders but its a street car so you might want to only do FG trunk/hood so you still have the strength for fenders. (I'm not fimiliar w/FG so I am guessing they aren't as strong). There is ample information in this thread but maybe you should reread this thread.
            1) cut the radiator support out
            2) cut the floorboards out
            3) cut the roof off
            4) cut the frame from the rear of the rear tire back, and the front of the front tire foward
            5) cut the car down the middle
            6) get someone to transport it to the local junkyard
            7)find new e30, start at #1
            8) repeat process until you actually know what the purpose of this car is
            • Scott///M
              • Feb 2006
              • 135
              #36
              I find it a lot easier to get the sound deadening off in the cold. When cold enough judicious use of an air chisel will strip the car in no time. It only took about 2 hours to remove all of that tar in 30'ish weather.
              While freezing temps do make it easier than normal. Heat, is by far a better way to remove all the goo.
              After weighing my car at a race in June (95º +), I discovered my car was 50 lbs over weight. So I popped open the trunk and in less than 3 minutes I had the sound deadening removed from the trunk. Wiped it down with some 3M adhesive remover and the job was done.
              Total time... less than 10 minutes
              Sorry, I tried a half dozen different search terms, but I couldn't find much. Planning on gutting my E30 in the next month or so. Looking for some idea's on what I can look for to remove from the car. The following list is what I've come up with so far:
              trunk tar
              carpet
              rear sears
              rear parcel shelf
              A/B/C pillar trim
              headliner
              door panels
              center console
              What else is there?? Is there any sound deadener inside the doors I can get out?? Not sure if I feel like taking out the dash, but if I do, I'll pull the A/C condenser as well. All the front A/C stuff is already gone.
              Can I remove the rear window regulators and somehow keep the rear windows up without worrying about them falling somehow?? Neither work anyways, and somebody was nice enough to silicone one shut before I bough the car anyways. I'd hate to do that to the other one, but it is a possibility. How much weight total do you think I can get out of the car and still have no issues driving it on the street (I'm not going to entertain idea's like cutting open the doors, etc., the car isn't caged). Thanks guys!!!
              Are you removing the stereo?
              If so, there are several items you can remove from the trunk. There's an amp and antenna motor (if equipped)
              If you install harnesses (which I hope you are) you can remove all the old belts.
              Be very cautious about cutting wires. The weight savings is minimal so I suggest you leave them in. However... if you are like me and don't always take peoples advice, be sure you know where everything begin and ends before you cut it.
              Label all wires.
              There are some wires that run through that amp in the rear that have nothing to do with audio. If I remember correctly, they are part of your brake lights or reverse lights? :roll:
              If you are removing the center console, you'll need to relocate you window switches. They can go where the speaker dial, hazard, ac and defrost buttons used to go. In order to get the passenger switch to reach that far, you will need to lengthen the wire. If you delete the window lock switch, you will need to do a wiring bypass to close that circuit.
              You may try looking for additional info in the "Preparing to Participate" section of the Spec E30 board.
              Good Luck
              Scott///M | 1988 325is | 2004 Z71 Suburban | 2003 325i
              • kendogg
                • Jul 2006
                • 348
                #37
                Label all wires.
                Good Luck
                The car doesn't have any radio in it. I haven't taken a look yet to see if there are even speakers in the car. It's a non-amp'd setup, the car was a base model '86 325. No hi-fi sound, no power sunroof, no cruise, etc. I haven't decided yet if I want to go removing wiring or not.
                I'm not installing harnesses because at the moment, I'm running stock cloth sport seats. If infact I do buy seats for this car, then yes, I'll buy a harness bar and harnesses.
                I do plan on removing the center console, but I plan on just zip-tying the power window switches in place somewhere close to where they are at stock. I'm sure I can find a suitable location that will keep them out of the way, and secured in place. And yes, believe me, I know all about the power window circuit breaker :) I'm thinking I will relocate the check control panel to somewhere in the dash, either near the radio location, or possibly right under there. Since I'll be removing the headliner, I don't want to keep that stupid thing up there, might as well put it somewhere useful. A friend has his zip-tied to rollcage, but alas, I don't have one of those :)
                Thanks for the tips though!!!
                • rwh11385
                  lance_entities
                  • 18403
                  #38
                  It's much easier to drive faster if you are not trying to brace yourself against the center console or door with your legs. Just think about a cheap Corbeau reclinable, or even stock sport seat to hold you in. And CG-lock makes the stock belts a lot better
                  • kendogg
                    • Jul 2006
                    • 348
                    #39
                    I'm not sure what you mean.
                    • erik325i
                      • Jan 2005
                      • 3567
                      #40
                      He means buy a racing seat and if you still want to use the stock belts, add on the CG-Lock to them. It helps.
                      -Erik
                      • kendogg
                        • Jul 2006
                        • 348
                        #41
                        -Erik
                        Hmm. Never seen this before. I always tighten the belt as tight as possible to lock it into place anyways, I am never bracing myself against anything with the stock sport seats. Granted, racing seats would be better, but thats not the object of what I'm trying to do. I'm trying to spend $0 to get a little more speed out of this car via weight loss before I upgrade cars, thats it. Nothing more, nothing less.
                        • rwh11385
                          lance_entities
                          • 18403
                          #42
                          ah, misread and thought you said nonsports. sports work well for a while (my mechanism broke and it "leaned" and then after I upgraded to a recaro I noticed steering was easier than before with the stock sport).
                          but the cg-lock makes it a lot easier to get buckled in and ready to go, and your chest belt is free to move as you steer while your lap is held tight and your body is in place. just a cheap replacement to locking the belt on the grid
                          • kishg
                            • Sep 2006
                            • 2624
                            #43
                            +10 for cg-lock.
                            '12 F30 328i Sport Line
                            '91 SpecE30 #523
                            '00 Ford F-350 Dually Tow Vehicle
                            BMWCCA #360858 NASA #
                            128290
                            • matt
                              • 3732
                              #44
                              Ken, I have a couple harnesses you can have in exchange for a little car help if you want. Schroth Rally 3s.
                              • kendogg
                                • Jul 2006
                                • 348
                                #45
                                The black ones you have in your car currently?? Will they work when I get a harness bar in the E36 when I buy one?
