New 15x8 wheel coming!
  • Massive Lee
    • Sep 2006
    • 6782
    #466
    Hi Joel
    It is true that the aluminum rim will be closer, but...
    Don't forget that wether it is mounted on 7" or 8" wheel, both with the same offset, the center of the tire remains at the same place as the offset has stayed the same. The mid shoulders (where usually rubs) also remains at the sam place. It is only around the rib, that it moves.
    massivebrakes.com
    • Mystikal
      Wheel Fitment Expert
      • 9602
      #467
      Bingo. Offsets, wheel widths, and section widths get complicated when you want to cut it close. Hence why I'm so abused around here.
      • JRKOUPE
        • Dec 2004
        • 3159
        #468
        tube science
        L
        I never knew/realized that........!!!!
        and it makes sense.
        ( Did you/any1 ever confirm if any of the e30 BBK's work on the 7.5 et25 ACT LS?)
        THANKS
        • mazur
          • Jan 2006
          • 731
          #469
          Any consideration for a 15x9 wheel? I'm sure there must be a market for it since 6UL/949 makes a set.
          • Massive Lee
            • Sep 2006
            • 6782
            #470
            What type of rubber do you expect to mount on 15 x 9 and how many do you think are interested in another 9" wheel. As you pointed out, the 6UL/949 already exists. Is there really a need for another one?
            Lee
            massivebrakes.com
            • cheades
              • 632
              #471
              The 6UL just sucks for the offset in 15x9. The 15x8 here will clear your massive race kit Lee, though for better clearance (more than 3mm) its best to have the wheel weights moved away from the edge of the spokes.
              • Tchao
                • Apr 2007
                • 223
                #472
                So he can run 275 rubber at the track!
                What a fag. :(
                • Massive Lee
                  • Sep 2006
                  • 6782
                  #473
                  Wow. Great news. Do you have any picture? I have a long list of trackers who would really appreciate knowing for sure if the 15" x 8" TRM wheel and Race kit are "good friends".
                  TIA
                  Lee
                  massivebrakes.com
                  • lucky7
                    • Jul 2005
                    • 692
                    #474
                    i would be interested in 16x9's.
                    needs spacers. 5mm up front, 10mm in the rear. if you want flush, that is.
                    they wont by chance be making these ET0? IMO the offsets are still too high.
                    -Dane
                    diving board division, bishez.
                    • 2002maniac
                      • 4260
                      #475
                      Lee
                      I agree. Too wide for 225's and not wide enough for 275's (better than 8" though)
                      Here's a 275 on a 15x8 rota with 1/4" spacer LOL
                      • turbo325i
                        • Mar 2008
                        • 1143
                        #476
                        Cameron??? ^
                        Turbo e30 M52. Built Motor, GT3582r
                        Watch my vids http://www.youtube.com/user/GrudgeRider156?feature=mhum
                        • 2002maniac
                          • 4260
                          #477
                          Originally posted by turbo325i
                          Cameron??? ^
                          Bret? Did Richard tell you about my car? I'll have it on the frame rack soon :(
                          • themitchster359
                            • 654
                            #478
                            that's a big ass tire...
                            89 Alpine White e30 325i
                            • xLibelle
                              • Aug 2004
                              • 2673
                              #479
                              is that -2.5* camber with pulled fender lips? does turn in hit?
                              ....looks like 0
                              • turbo325i
                                • Mar 2008
                                • 1143
                                #480
                                No he did not. What happened??? I can guess, and Im guessing its not so good...
