Roll bar padding?
    • 37832
    Roll bar padding?
    What do I want? I want something that's going to actually do its job [obviously] but can't spend an arm and a leg. Suggestions and links welcome. :)
    Thanks.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
  • joshh
    • Aug 2004
    • 6195
    "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
    ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
    • ddavidv
      • 344
      sfi certified only.
      • DynoTechMotorsports
        • Jun 2008
        • 116
        Hoerr Racing Products serves the motorsports industry by providing parts & accessories including lubricants, brake systems, shocks & springs, driver & crew to customers worldwide.
        this is were i get my gangsta gangsta stuff
        James Burger
        DynotechMotorsports
        • FLUTE007
          • 485
          i got mine from tms, local but expensive, 20 bucks for 3 feet iirc.
          • matt
            • 3732
            That's not expensive... that's what it costs. Even the cheap non SFI stuff is not much less than that.
            • Van Westervelt
              • 9365
              I would spend an arm AND a leg if it meant saving my noggin. ;) Cus thats how I do. Mine was about that $10 per foot or so.
              • JGood
                • Jan 2004
                • 7959
                You want SFI 45.1 spec padding, it is usually $18-$25 per 3 feet. I got mine from Bimmerworld.
                e30 restoration and V8 swap
                24 Hours of Lemons e30 build
                • Scott///M
                  • Feb 2006
                  • 135
                  if cost is a major factor. get the SFI stuff and put that in the places where your head could impact the bars, then use the cheaper not SFI stuff in the other areas.
                  While this is not the best way to go... your head is by far the most important part of your body that will benefit from the padding.
                  With all of that said... you should be able to get away with just 2 sticks for the drivers side only.
                  Scott///M | 1988 325is | 2004 Z71 Suburban | 2003 325i
                    • 37832
                    Thanks guys! Going to order this stuff up asap.
                    Grover Beach, CA
                    www.BimmerHeads.com
