racing dynamics sways
    Anyone running them for track? I am looking at a pair that I can get cheap. I think the front is 22 and the rear is 16. Thanks!
    '89 "is" = M technic II build mode.
    Lots of folks remove the rear bar entirely to help prevent lifting up the inside rear. The front IMO is pretty small and you can get that size off a stock vert.
    I/E has an adjustable 25mm bar, and Pelican sells an adjustable 27mm front bar.....according to their site.....I'll call them now and double check.
    88 325is
      I have heard that. I have also been told that ST has one, and I could get a good deal on their kit from SUMMET. I have not found it on their site yet...
        So I called Pelican the guy I talked to didn't know. I left a voicemail with Mike Ashcraft. Looked on H&R's site and they list a 22mm front.....which I'm more inclined to beleive.
        88 325is
          That sounds about right.
            I had my fingers crossed too. I'd like to find a thin wall hollow 27mm adjustable bar.
            88 325is
              Don't think anyone makes one. The IE's are the biggest, and I believe the H&R's after that, then I think the ST and Eibach are similar in size.
              And I believe they are all adjustable bars.
              www.gutenparts.com
                I think the ones the OP are talking about are NOT adjustable.....
                Yeah that's what I figured re. 27mm....
                I want a big ass bar to work with soft-ish springs.....If I lift the inside front who cares....it's not doing much anyways.
                88 325is
                  I am talkin' adjustable! :)
                    The convertible front bar is 21mm.
                    My 2.9L Build!
                      OK so I was wrong. Thanks for clarifying and making the info accurate...
                      But is the extra cost worth 1mm in diameter? Maybe when faced with trying to find a stock convertible bar. But I'd be more inclined to skip right to the 25mm
                      88 325is
                        Are the bars made of identical material and density (probably not the proper words for describing the things that effect the rate of the bar, but you get the point)?
                        e30 restoration and V8 swap
                        24 Hours of Lemons e30 build
                          I saw a IE front bar snap at the mounting point last friday at the track. Hasn't happened to any of the ST bars I've seen yet. i like my ST bars!
                            Maybe he didn't get rid of the pre-load. I've beat on mine (25mm IE bar) with no ill side effects!
                              Part numbers for a non M? I cannot find them on the sites I have been looking at.
                              Thanks!
