After the BMWCCA/NASA event @ PIR....
  • mazur
    • Jan 2006
    • 731
    ...I now have a new problem.
    Now how do I fix it? Thicker front swaybar I guess? :)
    Here's a link to more pics from the event: http://hancocks.smugmug.com/gallery/...3_dX6gR#P-1-15
  • matt
    • 3732
    Front sway bar suggestion is sarcastic, right?
    I'm not sure it's a problem that really needs a solution. If you want to keep that down, try more rear spring rate or more rear bar, if you're running one.
    • mazur
      • Jan 2006
      • 731
      More rear bar? Hmm...I took out the stock one to help the grip in the rear, which it did.
      I was thinking thicker front/rear sway bars to cut down some more on the lean. Seems to be a significant amount personally...
      And I thought this would help keep the front tire planted since there'd be less weight transfer. I guess I'm wrong?
      • Danny
        • 14216
        Pandashow brethen!
        • matt
          • 3732
          Think about what a sway bar actually does... As you apply more "up" load to the outside wheel, the sway bar basically moves that "up" force to the other wheel... bigger sway bar = tire farther off ground.
          • mazur
            • Jan 2006
            • 731
            Originally posted by Danny
            Pandashow brethen!
            I see. That makes sense. Thanks
            • Jon325i
              • 6934
              I know a couple of track car E30 owners who removed the rear sway bar - both agreed it made for an improvement in grip. What about different spring rates in back to better control body lean/roll? What are you currently running now? Are you running in a class which limits your options?
              Jon
              Rides...
              1991 325i - sold :(
              2004 2WD Frontier King Cab
              RIP #17 Jules Bianchi
              • mazur
                • Jan 2006
                • 731
                Jon
                I currently run 450/750.
                I was just thinking about getting some aftermarket swaybars front and rear and using the adjustability to hone the handling.
                • DEV0 E30
                  • Oct 2004
                  • 8901
                  Isn't the solution simple?
                  Don't drive as fast.
                  You're too fast Richard.
                  Slow down.
                  • RangerGress
                    • 91
                    Don't lose track of suspension basics. Most of what a sway bar does is keep the camber of the outside tire correct (meaning no worse then neutrally vertical) when the car rolls. But it does it at the expense of putting additional weight on the outside tire and lifting the inside tire. The weight transfer issue is significant because your inside tire will lose more traction then the outside tire will gain.
                    Springs, camber settings and swaybars are a "system", and you have to treat them as such. So all 3 need to be considered as a group. And also the balance of front vs. rear needs to be considered. A car has a "roll center" and a "center of roll resistance" which is a significant issue for sway bar balance.
                    And finally: Traction is good. Lifting a tire less so.
                    www.Gress.org
                    All that is necessary for the triumph of evil, is for good men to do nothing. -E. Burke
                    NASA SpecE30 #6, BMWCCA #161
