Oil sender adapter plate for M20
  • ScottL
    • Jul 2006
    • 24
    #31
    Yeah, I'd do the same thing since I won't be running the stock cooler. I'm sure you can find metric-AN adaptors at Summit that will do the trick. (I assume the threads in the adaptor are metric; doubt that they used the dreaded NPT threads...)
    • jvanhouten
      Site Sponsor
      • Oct 2007
      • 15
      #32
      Originally posted by ScottL
      Yeah, all I see at Canton's web site are the billet adapters. They look very well made. Not cheap, but that's OK. Maybe they don't sell the cast units any more?
      There are still out there, but I'm not sure if Canton sells them. For a race car, I'd definitely go with the billet adapter.
      I assume the 3/4" thread you're talking about is the spin-on filter stud on the stock oil cooler adapter? BMW used an SAE thread on that? Regardless, see my comments on using that below.
      Yeah, I was surprised too, but that is what it is.
      Kind of convoluted. I'd really like to pitch the original oil cooler adapter and just run lines straight out to the CM canister filter (AN -10 O-ring as you said). Less flow restriction, fewer couplings, lower chance of leaks. But, if I can't find the parts, I'll consider taking this route.
      I see your point, but I'm not sure I'd call it convoluted. To be honest, even though there are more "parts", I'd be more worried about a "custom" solution sealing well to to the block. In addition, with the stock manifold, you get a oil cooler thermostat, which you should rebuild while you have it apart--there is a kit for that. I will say that getting the 22mm adapters in tight and staying tight is somewhat of a pita. Lube the orings a little bit and use some locktight blue on the adapter threads. I've had the adapters back out when try to remove the AN lines.
      I have the same OP sensor set up you do: Metric-AN adapter on the original pressure switch outlet with a braided line to the sender mounted on the inner fender. The AutoMeter senders are really heavy and clunky. Works well this way.
      Cool. I think that is the way to go.
      Thanks for all the info, John!
      NP!
      John Van Houten
      Elephant Motorsports
      We are a Schroth Distributor
      Sparco E30 Strut Braces in stock!
      AST Monotube Dampers - Adjustable, Rebuildable
      Elephant Motorsports Specials!
      "Racing is life. Anything that happens before or after is just waiting." --Steve McQueen
      • jvanhouten
        Site Sponsor
        • Oct 2007
        • 15
        #33
        By the way, John, which header are you running on that motor? Looks like 6 individual flanges. I've heard that type of design is a bear to line up and mount. Did you have any problems with it?
        The exhaust system is a Korman setup that came with the car and I think the headers are the old SS race headers. I haven't had a problem with them, but I'm running something different now.
        That system will actually be for sale soon--headers to muffler. The straight (oval) center section needs to be replaced, but otherwise its in decent shape.
        John Van Houten
        • jvanhouten
          Site Sponsor
          • Oct 2007
          • 15
          #34
          Originally posted by bmwpower
          I like John's install. Any way to use the stock oil cooler with the AN-10 lines and some sort of adapters at the cooler end? Like a female version of the adapter you used on the OTHER end (at the bypass/mount)? I hope so...
          I'm sure there is, but why bother? Those adapters are bound to be pretty expensive and you might be better off getting an aftermarket cooler. If you are going through all the trouble to do the lines, remote oil filter, etc, why not go all the way and get a better cooler?
          John Van Houten
          • bmwpower
            • 1556
            #35
            I'm not planning on using a remote filter, just replacing the lines. Are there aftermarket coolers that mount in the same location as the stock cooler?
            Might be interested in the exhaust pieces. Let me know. I have a contact near Chicago that could pickup.
            Thanks....
            89 325is track project / 05 x5 / 99 M3
            E30 stuff for sale | Parts I'm looking for
            • bmwpower
              • 1556
              #36
              Any picts of aftermarket cooler installations?
              • bmwpower
                • 1556
                #37
                Any recommendations for aftermarket coolers that will fit in there?? Need to get this car back together....
                • Knockenwelle
                  • Jul 2008
                  • 395
                  #38
                  I've used coolers from RX-7s before with great success. Can't remember if it's the FC or FD, but the stock cooler is a very efficient, two-pass all-aluminum design, about 3.5" x 18" x 2" thick. It has regular 22(?)mm metric fittings, and the internal bypass is easy to plug. I have scored them in good used condition for as little as $40.
                  Mike
                  '91 325i track car. Mostly...
                  • Julien
                    • 7471
                    #39
                    ot question.. but will any oil pressure sender work for any gauge? I have some equus gauges (oil temp/oil pressure) in my car and was wondering if a simple VDO sender would work with them?
                    Thanks,
                    Julien
                    Build Threads:
                    • bmwpower
                      • 1556
                      #40
                      Thanks,
                      Julien
                      It will depend. They all have different ranges I believe.
                      • 5Toes
                        • 9836
                        #41
                        Bumping this thread.
                        So how much do you believe a machine shop would charge to drill and tap the oil filter housing?
                        • Elephant
                          Site Sponsor
                          • Jan 2008
                          • 328
                          #42
                          The filter housing? We drill/tap the large mounting bolt, not the housing. Drilling/tapping the bolt is easy peasy.
                          Cheers.
                          Jack Money
                          http://www.Elephant Motorsports.com
                          >> AST 4100 for BMW E30 $1649 <<
                          AST Monotube Dampers and Coilover Kits - Full Service Dealer
                          Schroth Safety Products Distributor
                          BMW Replacement Parts - 24/7 Secure Online Ordering
                          • iwantspeed
                            • 3164
                            #43
                            Cheers.
                            5toes
                            Talking about this bolt
                            Drill a hole of the correct size
                            for the tap you want to use
                            for the sender
                            Project
                            Parts for Sale
                            Feedback
                            YouTube Channel
                            • 5Toes
                              • 9836
                              #44
                              Im just putting together in my head how I am going to do this.
                              So have a machien shop drill and tap a bolt to 1/8" like this? - http://www.fastenal.com/web/products...l.ex?sku=38496
                              And then buy this adapter -4AN to 1/8" adapter and two of these fittings -4AN Fittings. ALso I will need some hose too - SS -4AN Hose
                              • 5Toes
                                • 9836
                                #45
                                Just going to use this.
                                Free Shipping - AutoMeter Metric Adapters with qualifying orders of $109. Shop Fittings and Adapters at Summit Racing.
