Transmission choices?
  • Dyno4mance
    • 345
    Maybe this should have gone in the transmission forum....but it is really a race question
    Please move if I have posted in the wrong area
    Are there any other transmision choices with better ratios available for cars that require the Getrag 260?
    Is anyone producing a straight cut gear set for a 325is?
    I remember seeing European Ford Sierra 5 speeds by quaife available on maybe VAC or someother vendors site...are they using an adapter plate or have I got my wires crossed?
    Thanks in advance
    2.7L M20 11:1 COMP 195 whp Dyno Dynamics 2380lbs
  • atomic
    • Jun 2007
    • 5691
    Not sure if this would work for you...
    • Dyno4mance
      • 345
      Thanks for that it is sort of what I want ...although that is a used one off that is probably sold by now and it looks like the company that made it are into 135s...is there not a company that just deals with the getrag range of the era
      Does anyone speak this language and tell me any more info on this...(Click "BMW E30" tab at the top of the page and scroll down to trans)
      semi slick,semislick,rennreifen,uhp reifen,slick,slicks,tracktire,trackdaytire,trackdaytires,racetires,racingtires,sportfahertaining,fahrertraining,fahrsicherheitstraining,fahrerlehrgang,freies fahren,renntraining,rennstreckentraining,pistenclub,rennstreckentraining,toyo r888,r 888,toyo,federal,rs595,rs 595,rs 595 racing,rs 595-r,rennveranstaltung,re55s,re540s.bridgestone,potenza,proxess,proxxes,hankook, z211, z 211,ventus,rss,yokohama,a048,a032r,a021,a032,radialrennreifen,diagonalrennreifen,rallye,ralley,rallyereifen,ralleyreifen,pilot sport,michelin,pilot race,pilot sport cup,cup2,pirelli,corsa,corsa race,pzero corsa,p zero,kumho,v70a,ecsta,v700a,dunlop,dz02g,d98j d 98 j,d01j,d 01 j,avon,zzr,cr500,z212,rs,evo,porsche,gt3,gt2,turbo,911,964,993,996,997,gt,carrera,turbo s,cup,porsche cup,clubsport,clubrace,trackevent,trackevents,trackday,trackdays,motorsport,motorsportveranstaltung,clubsportveranstaltung,rennstreckentraining,protrack,pro truck,pro treck,888,toyo,bmw dmv cup,remus,challenge,classic racing company,bmw1 challenge,bmw1challenge,bmwm3challenge,bmwm3 challenge,divinol cup,uh sport,bmw 325i dmv cup,dmv tourenwagen challenge,classic-racing-company,
      • z31maniac
        • 17566
        I believe www.metricmechanic.com will make you a 260 CR box.
        But I also think it is in the $3500 range.
        www.gutenparts.com
        • e30_325es
          • 1249
          e46 6 speed? e36 m3 5 speed zf?
          • Dyno4mance
            • 345
            Will the e36 tranny fit the M20?...any idea of the gear ratios in that tranny?
            • gearheadE30
              • Jun 2007
              • 3734
              Metric mechanic trannies will probably offer the best track longevity of the stock-ish options given the work they put into the parts.
              As for the 6 speed, it should work with a custom driveshaft, among other things. Since the 260 bolts to an M50 fine, albeit at an angle, it would make sense that the reverse is true as well.
              Project M42 Turbo
              • z31maniac
                • 17566
                ^The 6speed does work with a custom driveshaft.
                BierBrenner, has a How To thread on getting a 6spd in an E30.
                www.gutenparts.com
                • Knockenwelle
                  • Jul 2008
                  • 395
                  I'm using a Getrag 240 from a late 318iS. The ratios are a bit closer, as well as having a lower (numerically) first gear. The only fitment problem is that it is rotated 10 degrees relative to the block, so it sits a bit twisted in the car making custom shift linkage and mounts necessary. It IS technically a bit weaker than the 260, but behind your M20, it will last quite a while unless abused stupidly--this does not include track use. Fill it with MTL and go. Mine came out of a 90k-mile donor, and has performed great so far. It's also about 10 lbs lighter.
                  Mike
                  '91 325i track car. Mostly...
                  • z31maniac
                    • 17566
                    MTL? I was under the impression these cars trans called for ATF, have to double check the Bentley though.
                    www.gutenparts.com
                    • asubimmer
                      • 6482
                      yeah they do but I always ran MTL in mine. Its what the doc called for :-D
                      • e30_325es
                        • 1249
                        The fluid depends on what transmission label you have (260's), but the zf's take atf.
                          • 34844
                          it doesn't matter. Apparently the only reason some of them came with ATF was to save money. Why keep two types of fluids at your factory (to the tune of millions of gallons) if you can get away with using only one?
                          my G260 originally came with ATF (~220k). Been running Redline MTL in it for the last 30k, it's been just fine. Personally I would rather run MTL regardless of what the OEM says, ATF just isn't as good of a lubricant.
                          • gearheadE30
                            • Jun 2007
                            • 3734
                            iirc some have an orange sticker and others have a green stocker. Green sticker ones were supposed to have ATF. It makes more sense to run MTL though.
                            Project M42 Turbo
                              • 34844
                              yeah mine is a green sticker with over 250k, and I run MTL
