88 325 and wheelspin; lsd option?
  • Erick
    Official R3V Drifter
    • 11169
    Originally posted by asubimmer
    wrong ;)
    It was an OPTION on the 318is
    Popular option though. 4 out of 5 318iS' have LSDs that I've seen.
    ..::Support FullOpp::..
    FullOpp Stickers for sale!
    Feedback Thread
    • asubimmer
      • 6482
      yup mine was one of the unlucky ones
      • gearheadE30
        • Jun 2007
        • 3734
        Yeah, my 318is is up in STX because of the factory diff. It'd be very nice if someone made an appeal to change the rule or exempt the e30 from it, but I'm too lazy to do it myself. Turns out an e30 can be very competitive in STX anyway.
        Project M42 Turbo
        • SpecM
          • Oct 2005
          • 4531
          LSD was an option on all e30 (if not standard).
          '88 s-etas (and all etas 86-88.) have 2.93, some open and some LSD
          1989 cirrisblau-metallic 325i
          • z31maniac
            • 17566
            Originally posted by dicej32
            Thanks, my question was if it could be ordered with the lsd because SCCA rules only allow me to install the lsd if it actually ever came from the factory in that configuration.
            JR
            ix diff is viscous, but then I believe you'd have to swap in a complete ix drivetrain.
            www.gutenparts.com
            • whiltebeitel
              • Apr 2007
              • 2098
              That pretty much the way I understood it. :roll:
              '89 325i track sloot
              '01 530i daily
              -Enginerd
              • dicej32
                • 40
                I'm currently runnning in GS in SCCA. The Mini's will be gone from GS next year which will greatly improve chances of being competitive.
                JR
                  • 34844
                  are you sure? i think you are allowed to install an ix diff because they specifically allow VC LSD's. Also, they do not distinguish between a 325i and a 325ix anywhere in the rules or model listings.
                  • whiltebeitel
                    • Apr 2007
                    • 2098
                    *edit SCCA Solo 2009 rules:*
                    12.4 STANDARD PART
                    An item of standard or optional equipment that could have been
                    ordered with the car, installed on the factory production line, and
                    delivered through a dealer in the United States. Port-installed options
                    provided by the factory are considered to be the same as
                    those installed on the factory production line. Dealer-installed options
                    or deletions (except as required by factory directives), no matter
                    how common or what their origin, are not included in this definition.
                    This definition does not allow the updating or backdating of parts.
                    K. Limited Slip Differentials
                    ST, STS: No limited slip differentials are permitted except for
                    factory standard viscous coupler type units.
                    (basically allowing a specific FWD mazda to run in ST, as it came with a viscous LSD)
                    Stock Class:
                    L. Limited-slip differential, transmission and differential ratios, clutch
                    mechanisms and carburetion, fuel injection or supercharger induction
                    systems must be standard as herein defined.
                    So in Stock he should be able to install a factory limited slip as it could be optioned on the model he has (M20 engine), but it would require the car to be an iX or a clone thereof to do so is ST/STS.
                    '01 530i daily
                    -Enginerd
                      • 34844
                      right, I've seen the rules. However, my point is the SCCA doesn't consider the 325i/ix to be seperate models as far as I can tell. the AWD (or parts of it) can easily be considered a "factory installed option."
                      • whiltebeitel
                        • Apr 2007
                        • 2098
                        You're free to try, but I wouldn't. It seems pretty clear that if the car could not be ordered with a iX LSD (and it couldn't if it wasn't an iX) in the States, then it's not allowable. If you ran it in ST, you'd have to fight protests from any serious guy that caught wind of it.
                        He's running GS anyway, so a LSD in a factory-available ratio for the eta would be perfectly fine.
                        '01 530i daily
                        -Enginerd
                        • rThor432
                          • Feb 2007
                          • 3907
                          There were tons of optional ratios availible in Europe in standard medium case differentials (ie. for the E30). I'm almost positive that a 3.91 was availible, although it would have been a clutch diff and not a viscous diff. I'm not into auto-x for serious competition, so my take on bending rules might reflect that.. sorry if this post isnt helpful.
                          • whiltebeitel
                            • Apr 2007
                            • 2098
                            Sadly, it has to be a factory option available in the US. otherwise S50B32's might see more AX use...:)
                            '01 530i daily
                            -Enginerd
                            • rThor432
                              • Feb 2007
                              • 3907
                              Ha.. that's a valid point.
                              • Julien
                                • 7472
                                3,91 were used in german late model 325i
                                Build Threads:
