M14 x 1.5 to m12 x 1.5 Reducer?
  • HerbE30
    • Nov 2015
    • 538
    What I am looking to do;
    I have an M12 x 1.5 sensor that I plan to use as an auxiliary temp sensor for water/coolant temp. I would like to use the spare bungs on the thermostat housing, but both of mine appear to me M14 x 1.50 (please correct me if I am wrong).
    Which adapter should I be using for this? I know Lowes has brass (brass seems like a bad idea), not even sure if they are the correct pitch or should I order something online? Asking the pros.
    P.S. Lost a contact who I always borrowed a tap set from. I would prefer to use one of the spare bungs as that would look better in my opinion. Taking suggestions from the pros.
    Thanks in advance!
    20% Accurate
    Morty: Well Summer maybe people that create things aren’t concerned with your delicate sensibilities you know? Maybe the species that communicate with each other through a filter of your comfort are less evolved that the ones that just communicate? Maybe your problems are your own to deal with and maybe the public giving a shit about your feelings is a one way ticket to extinction.
  • HerbE30
    • Nov 2015
    • 538
    Will probably try to tap through the m14 bolt and thread it to m12. Seems a bit close. If it looks like it's going to crumble I'll just tap the proper side on the thermostat housing.
    Sensor gauge I wanted to run has m12x1.50. Late update.
    20% Accurate
    • digger
      • Nov 2005
      • 6137
      https://www.amazon.com/Hydraulic-Fit.../dp/B07MC9M4L5
      • HerbE30
        • Nov 2015
        • 538
        Hey Digger. Thanks for the reply! I forgot to update, but that is the exact thing I ordered. Drilled out the center and works great! I got on here looking for the washer that is suppose to sandwich between the plug and bung.
        Big thanks!
        20% Accurate
