A good sunroof FAQ sticky
  • GOOBER
    • 663
    Someone needs to write a really detailed write up on how the sunroof works (function wise and how it repels water), can be repaired, and common issues because most e30s have them and I can't count the number of times I went looking for information in a million different places.
    That is all.
  • e30this
    • 3580
    A sticky on fixing sunroofs would be amazing!! I need to fix mine ASAP..
    • Japandrew73
      • 2164
      it would help with my moonroof instal also...
      • SamE30e
        • Sep 2007
        • 4319
        Wouldn't mind knowing how to get the sucker apart to change the cables.
        1985 325e 2.8 Turbo VEMS
        • GOOBER
          • 663
          Originally posted by SamE30e
          +1
          That's actually pretty easy. Remove the panel, and unscrew all of the plates. Then crank the sunroof all the way as if you were cranking it open. Once it's all the way cranked back you should be able to just pull them out with some cranking to help them out. Now reinstallation requires some lining up and precise cranking.
          I just did this on my car.
          • ThaiRacer
            • 799
            Yeah my sunroof doesnt work when i roll back it doesnt go no where
            • StereoInstaller1
              GAS
              • 22679
              Mine has been fuxord for like 5 years, but has not gotten any worse.
              Closing SOON!
              Thanks for 10 years of fun!
              • ThaiRacer
                • 799
                i want to know how to fix the dam problem
                • OOMPH!
                  • 3487
                  Sounds like you need a new sunroof motor. I do too. There should be a blank plastic plate next to the check light panel, pull that off and the motor is in there.
                  • NC325iC
                    • Mar 2004
                    • 6565
                    if you take your crank off you can just push the cables in all the way forward and no precision cranking is needed.
                    • transatlantic0207
                      • Sep 2007
                      • 1624
                      installation is the only thing stopping me from buying and installing a moonroof....someone make a sticky!!!!
                      (OO≡≡[][]≡≡OO) ///Motorsport
                      In this world, things aren't black & white. Its Delphin!
                      Parts, Buy Them--> http://picasaweb.google.com/transatl...eat=directlink
                      Snowboard & video game stuff --> http://r3vlimited.com/board/showthread.php?t=148645
                      Originally posted by Steve92E34
                      Your car is breathing my air, and so are you.
                      AND you are both still slow
