clutch pedal not coming all the way back up HELP
  • mod_junkie
    • Jul 2012
    • 285
    my clutch seems to feel like it has no pressure and is not coming all the way back up ( I have to pull it up with my foot) its also making it hard to actually shift into a gear help I need to go to work in the morning!!
    Originally posted by Rocla
    And yes, you must remove complete assembly from the car, unless you are a gynegologist
  • glnr13
    • 1334
    clutch master and/or slave cylinder
    • ToPLeSS(e30)FeinD
      • Jul 2011
      • 2813
      probably low on clutch fluid, or you have a leak somewhere (or both). is the spring still on the back of the pedal? that should do most of the work.. is there fluid on your carpet under the pedal assembly?
      '89 Delphin 2.8 Cabrio
      '94 Yamaha FZR 600
      Originally posted by FlexdXJ
      Is that thing on air?
      • mod_junkie
        • Jul 2012
        • 285
        No fluids haven't checked the springs and Wtf is the clutch master at?
        • ky0u
          • Dec 2012
          • 808
          Yes check this
          It's located on the transmission bell housing. Attaches to these holes on the outside:
          Web Designer / Front End Developer
          My Portfolio & Website
          IG: @w_illriderz
          • daiku
            • Sep 2011
            • 22
            The clutch master cylinder is located basically below the brake pedal inbetween some metal, and goes through the firewall and connects to the clutch pedal on a black piston like thing.
            The clutch slave cylinder is on the driver side of the tranny bell housing ontop of it.
            Edit: This video should help you out a lot. http://www.youtube.com/watch?v=wdf--suwqw0
            • ky0u
              • Dec 2012
              • 808
              Oops yea, got them switched up
              IG: @w_illriderz
              • ToPLeSS(e30)FeinD
                • Jul 2011
                • 2813
                master is under the dashboard, attached to clutch pedal by that spring.. if that is leaking, its going onto your floor board or its going back into the reservoir, which means it wouldnt be working at all.. typically.
                best case scenario there is air in the line between the master and the slave.. bleed it and your problem goes away.. worst case scenario your clutch disk is defective (or old)
                '94 Yamaha FZR 600
                • ToPLeSS(e30)FeinD
                  • Jul 2011
                  • 2813
                  if its effected by temperature its almost definitely the fluid. fluid condenses when it gets cold and isnt sufficient enough to push the slave far enough.. gets warm and expands, act normal
                  '94 Yamaha FZR 600
                  • mod_junkie
                    • Jul 2012
                    • 285
                    The bracket holding the master cylinder broke apart causing it to pivot when pressed on.
                    • mod_junkie
                      • Jul 2012
                      • 285
                      yay how dafuq do I fix that? LOL
                      • ToPLeSS(e30)FeinD
                        • Jul 2011
                        • 2813
                        hahaha.. or that.. weld it/replace it... but either way you have to take apart the peddle assembly
                        '94 Yamaha FZR 600
                        • mod_junkie
                          • Jul 2012
                          • 285
                          Replace it with what? Is that like an actual part I can buy from AutoZone or some shit haha
                          • ToPLeSS(e30)FeinD
                            • Jul 2011
                            • 2813
                            junk yard. its the entire peddle box iirc. im not sure if the gas/brake are separate but from my understanding its all one piece.. and you have to replace the entire thing cause its all welded together
                            '94 Yamaha FZR 600
                            • ky0u
                              • Dec 2012
                              • 808
                              Kinda off topic but does your cylinder say "fag" O.o
                              IG: @w_illriderz
