Smog help?
  • smitche
    • Feb 2013
    • 326
    Smog help?
    Anybody know smog? Car failed yesterday. Failed 15mph, but passed 25mph. High NO and HC, CO was on the high side as well, but still within limits. From google, sounds like cat, any thoughts?
    My Build Thread
  • smitche
    • Feb 2013
    • 326
    I'm bumping this up... Based on everything I've read I believe I have 2 likely culprits. Plugs, wires, dist cap, rotor, injectors, hoses, etc... Have all been recently replaced. Timing was tuned recently as well. The only things I'm unsure of are the cat and the o2... When I bought the car neither of those items were on it and I bought both used. When I drove the car home, it pulled through the rev range very nicely, but I noticed that wasn't quite happening driving it around Saturday before smog, but it wasn't terrible. Well, I decided to disconnect the o2 and see how the car responded... Well, it idles higher, but pulls considerably harder. So I'm pretty sure it's the o2. Any other thoughts?
    My Build Thread
    • reelizmpro
      • 9559
      Post a picture of your results.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • smitche
        • Feb 2013
        • 326
        Here is a pic of the results.
        My Build Thread
        • smitche
          • Feb 2013
          • 326
          Going to go buy a new o2 today unless someone knows otherwise.
          My Build Thread
          • xxx-Lost-Soul-xxx
            • Apr 2008
            • 1953
            Well Before any smog test. I normally Do a fresh oil change,Run highest Fuel i can get 92 octane or higher. Make sure plugs are all gaped correctly,and normally run a new O2 sensor.
            • Thizzelle
              • 4422
              looks like a CAT problem
              "I wanna see da boat movie"
              "I got a tree on my house"
              • smitche
                • Feb 2013
                • 326
                All of that done with the exception of the o2... I always run 91, but that's the best I can get locally. Everything else had less than 50 miles on them prior to the test, including cap, rotor, wires, Tstat, tbelt, water pump, etc... Literally spent the last 3 months doing maintenance on the car. The only used parts were the complete exhaust and o2. Going to install a new o2 tomorrow and get retested. I really don't think the cat is bad after driving it with the o2 unplugged yesterday. There are no tell tale signs (rotten egg, back pressure, rattling).
                My Build Thread
                • reelizmpro
                  • 9559
                  Oxygen sensors are maintenance items so I would get a new one if the one you have is of unknown condition. They dont have to be terribly expensive. The cat fails low speed but passes high speed so its probably not getting hot enough. Did you run it hard right before the test? Are we talking about a used stock cat or aftermarket?
                  88 M3 - LACHSSILBER
                  • smitche
                    • Feb 2013
                    • 326
                    I wouldn't say I ran it hard, but I did drive it around for a good 30 minutes. I will really romp on it this time around. The complete stock exhaust was used, but I was told it was used by a shop to get cars to pass smog. I trust the seller, but I would rather not say who that was.
                    My Build Thread
                    • smitche
                      • Feb 2013
                      • 326
                      o2 did the trick, smog has been passed!
                      My Build Thread
                      • graphikg
                        • Jan 2008
                        • 1614
                        Can someone help with my smog? I have an s50... What do I need to get done?
                        • cervantes559
                          • Mar 2013
                          • 75
                          Hey did they run your car cold?
                          Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
                          • series88
                            • Nov 2011
                            • 1231
                            My e36 has the same problem. Boiled down to the cat pretty much. Temp before and after cat was the same. Cat isnt heating up at all
