I have smogged my car twice already and have failed both times due to the fact that is has high NOx levels. I dont want to spend money on buying a new cat. as well as sourcing the problem. If somebody would be kind enough and point me in the right direction to help me get a smog completed; so that I can get my new tags i would greatly appreciate it. Also, DMV is requesting it to be smogged at a STAR Station.
Car wont pass smog..... need some help!!
so you are saying that you don't want to fix the problem correctly but want to pass smog to get your tags?
Buy a cat, 02 sensor and do a cheap tune up. best $400 bucks you will ever spend.Comment
was the reading high at both 15 and 25mph? How high was it? never do a cat first. a new cat will mask other issues and just go bad again if you don't fix them.Comment
Or he can send me the $350 + I'll send it to a friend of a friend, of a friend's friend and he'll get his tags. ;)@IRON-E30 aka Edwin:DComment
garage queen 91 bmw 325is / 1972 Chevy El Camino 355 sbc 450hpComment
One of the main reasons why I dont want to spend the time trying to figure out what the problem is that fact that I have a s52/zf tranny/3.15 mcoupe diff waiting to be transplanted in.
But I failed at 15mph due to high NOx on both tests. I thought I had some air leaking after the maf so I corrected it and the numbers improved but barely.
The cat is fairly new and replaced a few years ago rite before I purchased the vehicle.
As soon as I get home tonight I will post up pictures of my smog numbers. A buddy of mine is a BMW tech iii at East Bay and he showed the measurements to his co-workers and they said it could be multiple things because I barely failing the smog test.Your signature picture has been removed. Refer to the Signature and Avatar Guidelines in The Rules.Comment
not trying to bust your balls here... but did you get the nice and hot before the tests? did it get on the roller right away, or did it have time to cool? based on my personal experience, and what you are telling me, I'll cast my vote for o2 sensor. Maybe see if you can borrow one locally just for the test.Comment
not trying to bust your balls here... but did you get the nice and hot before the tests? did it get on the roller right away, or did it have time to cool? based on my personal experience, and what you are telling me, I'll cast my vote for o2 sensor. Maybe see if you can borrow one locally just for the test.Your signature picture has been removed. Refer to the Signature and Avatar Guidelines in The Rules.Comment
