Reputable welder/shop for coilover welding
  • DiM
    • May 2012
    • 90
    I need my coilovers welded in. I had a local welder lined up but he fell through due to upgrading from his driveway to an actual shop. Maybe one of you guys are up for the task. Thanks guys.
  • JFarhanbod
    • 2151
    I'd recommend JMP but thats a bit far from ya.
    • Chilezen
      I weld cats
      • Dec 2013
      • 1944
      The shop I work at does weld, and does install coilovers, and has worked on many e30's, but I don't understand your need for them to be welded in? Our shop name is Advance Muffler, in Torrance, although, that also may be far from you.
      Currently building a badass coffee table
      Random stuff on insta @kevanromero
      • DiM
        • May 2012
        • 90
        The front coilovers need to be welded onto the spindle. I'm not sure of any front bolt on coilover kit except maybe ground control? Thankfully the rears bolt right up but then again they aren't even a true coilover.
        • 613EDRTY
          • Apr 2014
          • 267
          If you want true coilovers pretty positive they have to be welded. The only ones that don't require welding are GC/JOM/Raceland but they are just springs with adjusters.
          Rescued 1986 325e Coupe
          1988 325ix Touring 5spd currently being rescued
          Ottawa, Ontario, Canada :finger:
          • DiM
            • May 2012
            • 90
            I have Megan coilovers. The fronts are a true coilover the rears are just an adjustable spring and shock
