in need of wiring goo roo for m20's
    can u come help me with my m20 i got plugs with no partners lol just dont know wat goes where :P
    i can pay ya in cola as im under 21 :P
    DO WORK
    Give us some pics bucko
    We're out there in here.
      will do im goin up 2 family shop today to finish up sum lil stuffs on it :) exaust comes 2mro so it wont idle outa the head XD
      DO WORK
        THe darkest picture is of 2 wires that come off of the transmission
        DO WORK
          The plug in the 1st and the 2nd look like the speed or reference sensor AKA "pulse generator" in BMW-speak. I don't know if E30s have both like the E28 does. I never had a problem with them on my E30. See this: http://www.realoem.com/bmw/showparts...76&hg=12&fg=05 and this: http://www.bmwtechinfo.com/repair/ma...en/htm/167.htm
          Here's the E30 factory repair manual: http://www.bmwtechinfo.com/repair/ma...en/htm/002.htm
          Find your Electrical Troubleshooting Manual here: http://wedophones.com/BMWManualsLead.htm
            what one goes on the t/b though 0_0
            DO WORK
              and it cranks so thats hooked up like it starts just falls on its face
              DO WORK
                can someone tell me wer the wires off trans go :) and whats the tb wire :) itd helps alot , and what fuel line goes into the regulator ? im tryin to get this bitch to run
                right
                DO WORK
                  you should test you CPS sensor for failure if everything is matching up.
                    checked cps its good :) ohms is like 500-600 i forget
                    but i just dunno wer the wires off trans go ?
                    i think my idle problem is a fuel pump relay or concern ill diag it but just need input on wires off the trans ?
                    DO WORK
                      Wire off the trans goes up through the shifter and hooks up in the cabin by the shifter. TPS is on the TB and a 3 prong plug ovbviously. Return fuel line is coming off the regulator. Trace the one from the filter and that will be the feed and be opposite of that one.
                      Edit: if your talking about the plug in the last picture I have no idea what that is.
                      Originally posted by Roysneon
                      $5 shipped?
                      Originally posted by MarkD
                      You are a strange dude, I'n not answering any more posts from you.
                        ok found prob fuel pump has no 12v signal ill fix it and get back to yall
                        DO WORK
