Coolant overflow and noises when cold
  • makecopies
    • Apr 2013
    • 124
    Getting a slipping belt noise when cold the past couple of days goes away when warm and today the coolant tank overflowed a little bit.
    Im guessing maybe water pump?
    Does anyone know how much a timing belt/water pump change would cost?
    Anybody can recommend garage some place in DC/metro area?
  • John in VA
    • Aug 2007
    • 553
    Check the tension on the belt(s) - not uncommon as the temps drop.
    Sounds like you need to replace the coolant reservoir cap.
    Look for previous posts re: area shops in this regional section, or the following:
    http://forums.bimmerforums.com/forum...le-Atlantic-US
    Good luck!
    • makecopies
      • Apr 2013
      • 124
      You were right the alternator belt just came off and now I'm stuck on the side of the road
