Colorado general chat...
This is a sticky topic.
  • 325ix
    • Aug 2009
    • 7783
    #9811
    I'll give you two dollars, a gum wrapper, and some belly button lint. I'd like to see David top that.
    • iamsam
      • Jun 2008
      • 176
      #9812
      I am trying to sell these to someone who actually wants them. I think $40 is fair, that's $10 per steel wheel.
      • lambo
        Captain Scene Points
        • 10953
        #9813
        Originally posted by iamcreepingdeath
        it would be great if you could, but I could bring them to south denver on Monday when I go to work.
        If that's possible, I'll take them off your hands. Those would be nice for winter tires...are they 14x6?
        • iamsam
          • Jun 2008
          • 176
          #9814
          I think 14x5.5 or something. Nice for some 185 treadwidth skinnys to dig through the snow.
          I just got a second set of basketweaves w/ some CL tires (that aren't bald) so I need the money more than I need the steelies.
          • blefevre
            • Dec 2008
            • 4287
            #9815
            I pulled one plug from the Ti and it came up covered in oil. I did some searching and found out that the valve cover gasket seals tend to go bad, which leaves oil "in the well". Very common problem. There was definitely oil in the well as it was on the spark plug wires as well. When I pulled the plug out it was drenched in oil. All wet oil that wiped right off. I am thinking that it's just the valve cover gasket, and when I pulled the plug out it picked up all of the loose oil.
            If it was a piston ring, or head gasket, wouldn't the oil be burnt on there and not be wet? I ordered a valve cover gasket and I will be doing that, but I want to know if I should be worried about the piston rings or head gasket.
            - E30, DSM, Golf R, Mazda 3 Skyactiv
            • Roland H
              • 4480
              #9816
              Likely just the VCG. You'd be burning a ton of oil if it was a ring/HG problem.
              • blefevre
                • Dec 2008
                • 4287
                #9817
                Yeah. I really have no idea if it was burning oil or not because I never drive it. I haven't heard anything about it smelling bad while driving, so I'm sure it's just the VCG.
                • Roland H
                  • 4480
                  #9818
                  If the oil level drops significantly between oil changes, that would be another indicator. Compression test will indicate as well usually.
                  • blefevre
                    • Dec 2008
                    • 4287
                    #9819
                    Oil level doesn't drop. I will change the VCG and plugs and see how it does after that.
                    • conway
                      • 366
                      #9820
                      +1 VCG
                      Doing mine this week, along with a lot of other maintenance i've been putting off.
                      Eastwood fender roller available for rent in Boulder. PM ME
                      • conway
                        • 366
                        #9821
                        Anyone have an extra m/s50 valve cover?
                        • Iannfld
                          • 327
                          #9822
                          Got my new suspension installed on the wagon....New Bilsteins, H&Rs, lowering links for the rear air bags, new control arms,, thrust arms, strut mounts, subframe bushings, rear brakes, tires, wheels....Got a factory M5 bumper to put on the front, just need to get it painted. Works well for a daily driver.
                          Before (stock wheels and sport suspension):
                          After:
                          Interior with M5 titan Trim:
                          • blefevre
                            • Dec 2008
                            • 4287
                            #9823
                            That looks awesome. I love those wheels on the wagons.
                            • fsmtnbiker
                              • Feb 2011
                              • 617
                              #9824
                              Love the wagon. That looks fantastic.
                              Chris
                              97 M3
                              01 325
                              Weston Auto Gallery
                              • 325ix
                                • Aug 2009
                                • 7783
                                #9825
                                I want your seats and steering wheel.
