Swaps & Emissions in CO
  • monkeytaco
    • Jan 2010
    • 882
    I've been searching high and low all over r3v and the web, and can't find any info about passing Colorado(specifically Denver) emissions with a swapped car.
    Does anyone have an m5x swapped car that has passed emissions? Any hiccups?
    I have almost all the parts for the obd1 swap, but I also have the complete obd2 setup (including all the matching ews stuff & keys) and keep waffling about which way to go. I am going to be driving this daily and need it to pass emissions!
    If I go with obd2, all I need is a driveshaft and I'd start swapping right away and sort that out when I got to it, but I love the clean engine and bay of the obd1 setup...
    Any advice/thoughts are really appreciated.
    Looking for a clean e30 shell for a project.
  • Roland H
    • 4480
    It's based off of the car, if the car is OBDI (anything 1995 or earlier), you only have to pass a sniffer (and a visual inspection depending on where you take it). If the car is OBDII, it has to retain all OBDII electronics. However this is only in counties that require emissions.
    • Atreus
      • 1846
      yeah, so if you registered it in Kiowa or something, you would be fine.... hint hint.
      1991 325iC - Mauritsblau sumthin metallic blue. DEAD
      1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
      1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
      1991 325iC - Calypsorot Metallic
      1994 540i - Granitsilber
      Originally posted by scabzzzz
      I've had blunts cock in my mouth, but I'm not gay.
      • monkeytaco
        • Jan 2010
        • 882
        Okay, next question, where's the best place to take it for Denver to easily pass the visual inspection? :)
        • stoliver54
          • Apr 2004
          • 312
          I've just gone to the e-test place in Boulder, and didn't have any problems.
          That could be that the previous owner had gone above and beyond our requirements to make it legal in CA.
          I really don't think you are going to have a problem monkey, they most likely won't realize that it is a swapped engine.
          Wheelgap is like a vagina. The more fingers you get in, the worse it is.
          Originally posted by Chachi
          young chicks are not keepers. they are for fun.
          • downforce22
            • Aug 2009
            • 3191
            apparently in el paso county (CO springs) you don't have to pass emissions. so eventhough my roommate is from Longmont and needed a test for his car they wouldn't do it down here. Just something to think about, i'm not sure which counties have to have emission tests
            • surebimmer
              • Jan 2004
              • 978
              Two speed or dyno test?
              • Roland H
                • 4480
                most of them are dyno, but I know of a shop that does 2 speed tests for cars older than 82 or 83.
                • monkeytaco
                  • Jan 2010
                  • 882
                  I live in Denver county and they do require emissions. I've owned several cars here, the oldest being a 92 honda accord (I'm sorry), and they have all been dyno tested.
                  Never had a car fail, but I'm also hoping they won't know the difference between the engines...
                  If I do have a problem, I'll probably go through the procedure to get it marked a custom vehicle. Running OBD1 like the car originally had will probably help my chances of passing without question.
                  Who's got an ecu and harness they want to sell me!? :)
                  • ZombiE30
                    • Dec 2009
                    • 438
                    as long as the engine runs properly and you have a catalytic converter, it should pass.
                    visual inspection should go ok as well, because those people don't get paid enough to give a shit (and it's unlikely they know anything about e30s)
                    mainly they're looking for leaks or signs that the car is crap, and even then, I saw one car dump half of it's coolant during the test and they still passed it.
                    As long as you don't have a barrel of nitrous or something plastered in radioactive stickers, it should be fine.....
                    Originally posted by stoliver54
                    Aw, balls.
                    FS: assault gear....
                    http://www.r3vlimited.com/board/showthread.php?t=159253
                    • iamsam
                      • Jun 2008
                      • 173
                      no emissions in Larimer co!
                      • hyperE30
                        • Sep 2009
                        • 2202
                        dooo it!!! when I took mine and since it had low pro tires they thought it was a FWD ha such idiots!!
                        make sure most hoses and wires are connected... I took my truck and for one hope it didn't pass so I hooked it up to nothing and I told them WTF last year it passed so he inspected again couldn't find the missing hose so It passsseeedd!!!
                        HyperWerkz
                        89 mtech2, s50, AR Kit, borgwarner s362, e-85, 15psi... 592whp
                        " enjoy the show "
                        • Hansel
                          • Oct 2009
                          • 218
                          I have an s50 swapped 90' 325. I live in Boulder and had to do the dyno test. Failed the first couple tries w/ basically straight pipe (the cat that was on there when I bought it was about 25% the size of a stock one. I was right over the limits, but just barely.
                          I finally gave in and got a new cat put on and it easily passed.
                          • monkeytaco
                            • Jan 2010
                            • 882
                            I'm wondering if I can use the cats from the e39 528 that the engine is coming from, I can weld my own setup so I might get creative...
                            • stoliver54
                              • Apr 2004
                              • 312
                              I have late model E36 midsection, including cats and mine passed. I would assume that the E39 cats would work fine
