A friend and I obtained an 88 325is for 400 with some frame damage, and parted it out. We are now trying to turn it into a tailgater trailer (half bbq with room for a cooler and misc party supplies). We are trying to decide whether to keep the IRS, or put in a solid rear axle... Any opinions or suggestions? Also, if we do keep the IRS, we need another differential (my friend used the 4.10 LSD on his). Hopefully someone can donate an empty case from a LSD conversion if we do go the IRS route. TIA.
e30 Trailer Conversion
Originally posted by Farbin Kaiber View Postpull the diff and drive axles. BAM! Done.
Originally posted by Teaguer View PostIf you have to ask these fundamental questions then its NEVER gonna happen.
/ thread
exactly, Cut the axels right behind the bearing. That way it will keep the split bearing together. Other wise, Like nando said. That bearing will be shot
Make sure you take the CV apart after you cut it. Or you will get it slinging parts.sigpic
