Cheapest place for front end alignment?
  • Matt-B
    The Waffler
    • 3856
    Called some various place, all with their heads up their asses.
    Quotes from 60-135$
    anyone cheap. For Christ sake, only the tierods get adjusted.
    thanks for any help
  • 619E30
    • 1753
    Free at my school. lol
    Originally posted by audiquattrot
    bimmers b4 b*tches....remember that.
    1990 Alpinweiss 325i - secret 500whp build
    2000 Audi S4 B5 Laser Red
    1990 Nissan 240sx - Drift Missile
    2006 CBR600RR
    • Hellabad
      • 807
      Call me today and I will tell you how to do it. I wont be around tomorrow.
      You will quickly learn how to do things cheap when you race a car while you are paying for your own college.
      Jay (530) 677 8600
      Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
      Ground Control Gallery
      The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
      • 1craze30
        • 1224
        they want 60-135 for toe-in only adjustment? wild
        • Matt-B
          The Waffler
          • 3856
          yea. I was like are you kidding, and hung up.
          • daniel
            • 6703
            if its $60, just do it. that is a good deal. Most places charge around $100 because they still check your thrust angle and BS like that with the laser guided super duper alignment gizmos.
            http://instagram.com/dslovn.drives
            • Matt-B
              The Waffler
              • 3856
              I dont have 60$. Going to try hellabad's idea tomorrow
              • HellzMindPlaya
                • 395
                basically you just find some way to measure the distance between the fronts of the two tires, and the backs of the two tires. When I helped adjust my toe-in we just used some plates that went against the outside of the tire and had slots cut in it for a tape measure blade to go through it. I don't remember what the measurements were, but if you have no toe-in in front of the tire would measure like 60" and behind would measure the same 60". then you just turn the adjusters so that the tires have like 1/16" toe in and you should be good. I think that is all we set mine for, and it hasn't giving me an ounce of trouble. We also set my camber, but you need a fancy tool for that, and then camber/caster plates so you can even adjust it.
                e30 Sold long ago - Too many BMWs since then... For now 2006 M5
                • hoveringuy
                  • Dec 2005
                  • 2721
                  I used a laser level. I lined it up with the tires, marked the beam on the floor behind the tires and 10' in front, did some trig to find the angle.
                  Adjust, repeat.
                  • daniel
                    • 6703
                    Originally posted by Matt-B
                    I dont have 60$.
                    then you can't afford a tank of gas either. stop driving until you get a job or something.
                    • Matt-B
                      The Waffler
                      • 3856
                      I can afford to drive to peoples houses to work, and make the little $ I do. I dont have 60$ extra, Trevor. There called Toe Plates.
                      Thats what Im trying.
                      • ejnight
                        • Apr 2007
                        • 3488
                        The line up shop on 102 off Halsey, Portland. Ask for Charlie $45
                        http://raceskids.com/
                        • Zues
                          • 145
                          Firestone has lifetime alignment $139.
                          90 m20is
                          • Matt-B
                            The Waffler
                            • 3856
                            thanks anyways...I dont want to pay that much. trying to do it myself tomorrow
                            • s_ribs
                              • 349
                              Post up what hellabad told you to do and how it worked when you're done.
                              1991 318i Sedan Project
