Motor swap "es" into "is"
  • BigBillions
    • 123
    Ok guys i have a question about a "es" motor swap into a 1989 "is" body. The "is" body has the "is" wiring harness ,ecu, and sensors and the "is" motor can rev alittle higher than the "es". 1. so the question is should i use the "is" intake maifold and afm or the "es" one when i do the swap? 2. also should i switch ecu's so that it cant over rev and harm the "es" motor. 3. also another question is there a differance in cam size between the two and witch one is bigger? 4. and final question is what would i have to swap in the "es" motor to take the higher reving. would i just need to change the valve springs to the double "is" valve springs or would i need to change the valve spring and cam. thanks you for your time and experience hopefully some one can shed some light on this. my goal here is to have a es motor have the same rev limit as a "is"
  • Wschnitz
    • 8089
    Why would you put in an e motor. Your doing alot of work for a poor engine hp wise. Why not pull a m50/m52 and get similar mpgs and twice the hp.
    willschnitz
    • Wschnitz
      • 8089
      And the higher rev in a es is not possible by my understanding, it would melt the engine.
      willschnitz
      • Knoepfler
        • 631
        i hate this thread
        • e30austin
          • 15382
          You can't be serious.
          • 5Toes
            • 9836
            Stroker!
            • Keith M
              • 2338
              Do a little research first. You can pm me if you have questions.
              • bmwm42
                • 6300
                This dude is a fucking troll asked if my 318I had an m20
                Originally posted by bmwm42
                PNW vulture pm me for parts
                Strategic nw e30 command
                • monster89
                  • Sep 2011
                  • 234
                  i would also go with the s50
                  • spiDmang
                    • 3941
                    I would go with a k20a motor set up. Wait...
                    91' 318iS - S54/6MT Swapped
                    08' E90 M3 6MT - Daily
                    Originally posted by IronJoe
                    Originally posted by 2mAn
                    • AbeSonic
                      Price check on Vagiclean, aisle five. I repeat: price check on Vagiclean, aisle five. That's Vagiclean. We've got a customer down here with a full-on fallopian fungus. I'm baking a loaf of bread and I think it's sourdough.
                      • 3635
                      Hey man let me get that I motor when your done pulling it ;)
                      out dated sig is out dated
                      • BigBillions
                        • 123
                        Wow what the hell. seriously .............. im asking these questions becuase i havent found a i motor. and m50 swap is alittle out of the price range. also building a stroker means putting a i head on a e block. so the questions i had for putting a i cam and i double valve spring into a e head isnt really a stupid question.
                        • Wschnitz
                          • 8089
                          From what i understand what your asking is dumb and not possible.
                          willschnitz
                          • BigBillions
                            • 123
                            why is it dumb???????????? thats why im asking these questions. because i dont know. can you tell me what the differences are between the 2 heads besides different size valves.
                            • RUFFLZ
                              • Apr 2011
                              • 3122
