Price check on Vagiclean, aisle five. I repeat: price check on Vagiclean, aisle five. That's Vagiclean. We've got a customer down here with a full-on fallopian fungus. I'm baking a loaf of bread and I think it's sourdough.
Ok guys i have a question about a "es" motor swap into a 1989 "is" body. The "is" body has the "is" wiring harness ,ecu, and sensors and the "is" motor can rev alittle higher than the "es". 1. so the question is should i use the "is" intake maifold and afm or the "es" one when i do the swap? 2. also should i switch ecu's so that it cant over rev and harm the "es" motor. 3. also another question is there a differance in cam size between the two and witch one is bigger? 4. and final question is what would i have to swap in the "es" motor to take the higher reving. would i just need to change the valve springs to the double "is" valve springs or would i need to change the valve spring and cam. thanks you for your time and experience hopefully some one can shed some light on this. my goal here is to have a es motor have the same rev limit as a "is"
After reading this and then re-reading it again. I think I may have deciphered what your trying to ask. Unfortunately if you transplant a M20B27 which is a es motor as you call it, it will not run like a M20B25 (is)
Even if you switch the manifold, and ecu and cam it still a M20B27 witch will fall apart and break at higher RPM's it was not meant to achieve. Its more complicated than you think. All putting a 885 head (is head) on a M20B27 block will accomplish is making a Super Eta. Which no one really cares that much for anyway. If you really want to liven your eta up, buy a chip for it.
Wrong.
My eta (and the countless other swaps we did at my shop) went from ~95whp to ~140whp by adding the 885 head (aka 327i or budget stroker), the seta has pistons shaped like the b25 (i motor) but displaces 2.7l. The bottom bottom end will not self destruct because you are revving it higher, my limiter is set to 6800RPM with the eta crank. The same bearings are used in both motors and you saying that the eta bottom end will blow up because of a longer stroke is absurd as many people put the 3.0 crank in m20's all the time to make a real stroker. The 885 (i) head on an eta has lower compression due to the flat pistons, the i and seta pistons are domed to match the 885 head chamber.
If you don't know what you are talking about, please don't give out wrong info.
When the PO posts why he wants to do the swap, I'm sure we will understand. He only has an eta motor available and an i car/electronics.
EDIT: The race car also has an eta bottom end with 885 top end and .020" thinner MLS gasket making 357whp.
super eta has domed pistons asshole! only offered in 88. it also has an 885 head, but with eta valve train. valve train and cam can be swapped for normal i valvetrain/cam and you have a 2.7i that holds normal compression.
Yup. I have one getting ready for rebuild here at the shop :)
The springs are actually dual springs like the b25, the cam is it's own, neither the eta nor the b25 share this cam (have some of all of them lol). Take seta, swap the cam/ECU and you have a high revving stroker that makes more power than the budget stroker.
you sir sound like you will appreciate the seta i am building
fresh 885 head for parts, 323 cam, euro lightweight oem fly wheel.
motor will be stripped down, sent to machine shop, rebuilt to 0 miles and o-ringed.
hopefully after the break in period i will have saved enough cash for the turbo build
