Looking for someone to help out with installing Rear E30 springs Seattle (UW)
  • robert1700
    • 1151
    Title says it all. $50 tip is involved. I cant get the training arm down enough on either side. I have a spring compressor.
    In UW area
  • BraveUlysses
    • Jun 2007
    • 3781
    Did you try disconnecting the shocks? You shouldn't need a spring compressor at all.
    • bmwm42
      • 6300
      Disconnect the sway bar links and the fuckers fall out
      Originally posted by bmwm42
      PNW vulture pm me for parts
      Strategic nw e30 command
      • dantheman
        • Sep 2011
        • 383
        Did you disconnect the shocks as well as the diff? If nothing works, have someone use a crowbar to hold them down while you pop out the springs.
        • bmwm42
          • 6300
          Why would the diff be disconnected
          • ballarde30
            • 369
            Disconnect the shocks from the trailering arms. That will do it.
            1991 318i - Ground Control, 4.10 Limited Slip, Dinan Chip, Sport Interior - Daily Driver and Track Toy - Sold
            2005 Subaru Legacy 2.5 GT Limited
            2006 Subaru Outback 2.5i
            • thebutterson
              • 463
              I go to UW and may be able to lend a hand in the afternoon if you're real close. Send me a pm tomorrow if disconnecting the shocks and sway bar doesn't do the trick. Do you have a large prybar? I just did the springs on mine and that's all I used.
              • robert1700
                • 1151
                Yep and yep
                • Wschnitz
                  • 8089
                  Back is fairly easy if I'm not mistaken, pop off the sway bars and they basically fall out.
                  willschnitz
                  • CorvallisBMW
                    Long Schlong Longhammer
                    • 13039
                    Ya, no need to fuck with the diff. It's literally 2 bolts on each side. Shock off, swaybar disconnected, boom.
                    • 42000
                      • Jul 2012
                      • 222
                      When I did mine they were hard to get out no matter how far I pushed down the trailing arms. SO I compressed them a little and then pushed down the trailing arms and pulled them out. I go to UW and would give you a hand..
                      • AirplaneBuilder
                        • 823
                        Replacing rear springs should take 30 minutes max and thats from taking the jack/stands out, replacing springs, drinking a beer and putting the jack/stands back on shelf... like everyone said, unbolt the shocks and sways and your good to go.
                        1989 Zinno 325i S50 ZF320
                        • djjerme
                          • 5082
                          ^^What he said, it should take someone longer to drive to your house then it does to swap them..
                          2016 Ford Flex
                          • 10Toes
                            Me Father Was A Tree
                            • Jan 2008
                            • 61222
                            Take the ebrake off also, it will let the trailing arms drop more.
                            • robert1700
                              • 1151
                              Car is on a lift, the sway bar and socks are disconnected, doing a h and r swap, fronts went fine. Even with a compressor the trailing arm will not drop enough, I have never been stuck like this before.
                              Sunday anyone?
