Need some help guys, 325e starts and dies.
    Originally posted by bmwm42 View Post
    Could try a new ignition switch
    I was sure that it was the ignition switch so I put a brand new one in this morning and it made no difference.
    1989 325i Alpine s52 coupe
    2003 540i M-Sport 6 speed
    2003 X5 3.0
      Check main relay make sure the tdc pin is still present in the fly wheel or at worst the ecu
      PNW vulture pm me for parts
      Strategic nw e30 command
        Fairly certain it's not the crank sensor.
        I was trying to think about things that I've done that resulted in like symptoms. The first would be an unplugged (non-functioning?) AFM. You may have been on the right track replacing the ignition switch. Have you looked at the ETM and checked the other components and connections in that circuit?
        Do your cluster warning lamps remain on when it dies?
          The warning lights do come on when the car dies. I have a few extra eta ecus so i tried one a few days ago when this happened, no change. I also have a brand new main relay for troubleshooting purposes and i tried that with no change. I exchanged the unloader relays with the headlight relays with no change. I have unplugged and tried to run each of these sensors with no change afm, tps, baro sensor, o2 sensor, cold start injector, idle air control valve.
          2003 X5 3.0
            Well obviously the car is getting signal and the second he releases the key poof no signal, obvious the issue is something electrical,
              Jump pins 30 and 87 at the fuel pump relay socket and see if it will keep running.
                I wont be back home to to try that til friday morning but if it is just to power the fuel pump i know that wont work because spraying my own fuel down its throat results in no change. It seems like it is losing spark right after starting. Does anybody know what the second sensor on the bell housing actually does?
                2003 X5 3.0
                  If the crank speed sensor is not functioning correctly the car would miss at a constant speed the crank reference sensor if bad the car won't start bc dme cannot locate tdc so it won't ground anything
                    Brake cleaner won't make the car run.
                      Did you ever figure out the problem?
