Need some help with my 24v....m30 starter needed
  • spiDmang
    • 3941
    Does anyone potentially have a used, known working, m30 starter I could borrow for a day?
    My 24v swap is having a hard time starting, and it seems like its the flywheel/starter combo I have (m30 240mm single mass fly/24v starter...the swap won't turn manually with a 22mm and a breaker bar...FCUK!)
    Please let me know
    91' 318iS - S54/6MT Swapped
    08' E90 M3 6MT - Daily
    Originally posted by IronJoe
    Originally posted by 2mAn
  • 2mAn
    SeƱior Mod
    • 21040
    good luck Brad, cant wait to see the car completed. it will look like a ridiculous sleeper on the stock bottlecaps
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • BK544E34
      • May 2012
      • 172
      Austin is having this problem too on a car that he was working on with his buddy.
      I think we narrowed it down to being a problem somewhere between the motor and the trans and not the starter.
      1999 M Coupe
      2014 X1 xDrive35i
      2000 P38A HSE
      1989 Lachs 4 Door
      Instagram: MCoupeKim
      • GunMetalGrey
        • Dec 2010
        • 1499
        Take out the plugs and try to turn it over with the crank, if you can't turn it over without plugs you may have another issue.
        Example: a friend rebuilt his motor and never tightened the bolts for his rear main seal, he torqued the flywheel down and the bolts jammed into it keeping it from rotating.
        Sent from the future. Or my phone, who knows.
        • spiDmang
          • 3941
          Pulled the starter, and the engine free'd up again.
          Excited to finally make some more progress!
          • AustinK425
            • Sep 2011
            • 831
            Dope! Was hella sad when I texted you and you said you were having troubles.
