FS: 5-lug, manual swap, NIP
  • Mafiaracers
    • 353
    FOR SALE: the better part of a 5-lug and manual swap.
    Was acquiring parts for some time now to do a manual swap and 5-lug conversion on my late model coupe. I have since decided on a new direction and am yarding off my parts. Prices are OBO. Open to offers so long as they are reasonable. Local preferred, will meet if reasonable distance. Will ship big stuff if we can agree on price for that service.
    Thanks for looking
    call, text, PM, email
    Chris 503-490-4248
    Parts:
    318ti trailing arms and hubs SOLD
    getrag 260 transmission $150
    late model drive shaft for coupe SOLD
    Trans mount bracket SOLD
    95M3 control arms (does not have new ball joints yet) $100
    95M3 calipers, pins, brackets front and rear (need rebuild) $100
    Single mass m20 flywheel (needs surface), sach plate and disc in excellent condition SOLD
    Z3 steering rack (reman) with NIB tie rods and PS delete plate SOLD
    Bimmerworld v2 braided clutch line SOLD
    UUC trans mounts SOLD
    UUC clutch stop SOLD
    Jaffster shift knob $80
    Ireland brass pivot pin SOLD
    late model pedal assembly SOLD
    NIB: $make offer
    clutch master and slave cylinder SOLD
    rear main and housing sealSOLD
    shift boot SOLD
    guibo SOLD
    pilot bearing SOLD
    trans front and rear seals SOLD
    center support bearing SOLD
    throwout bearing SOLD
    front window gasket and lock strip IN BLACK $100
    Chris Woods
    https://www.facebook.com/munichmotorworks
  • kronus
    • Apr 2008
    • 13032
    oh excellent, I need a bunch of this. sending PM.
    cars beep boop
    • Mafiaracers
      • 353
      updated
      Chris Woods
      • mattewhite30
        • Jan 2011
        • 125
        pm sent.
        • EN318isPDX
          • Oct 2007
          • 4373
          pm sent
          • Mafiaracers
            • 353
            responded
            Chris Woods
            • ser1992
              • Feb 2013
              • 482
              have you ever driven the car the tranny came out of of know its mechanical condition? mine has developed a grind, if i swapped one in that was also busted... >:(
              • Mafiaracers
                • 353
                I purchased the transmission from an older gentleman who had plans of m20+ 5-spd swapping his e21. It sat in his garage for about 2 years before his plans fizzled out and I acquired the transmission from him sometime last year. So it has been sitting for 3+ years as a paperweight. From what I understood in my conversation when I purchased it, it came from a perfectly good running 325i chassis who's owner had removed it for an m50 swap. Supposed to have around 150k on it.
                Far as I can tell, it spins very freely, spins silent. I attached a shift linkage to it and bench-tested the lever...hits all gears no problem.
                I hope that answers your question.
                Chris Woods
                • EN318isPDX
                  • Oct 2007
                  • 4373
                  Rear trailing arms/hubs are sold! Thanks Chris
                  • Mafiaracers
                    • 353
                    trailing arms sold. Thank you!
                    Chris Woods
                    • e30austin
                      • 15382
                      And so it begins...
                      • EN318isPDX
                        • Oct 2007
                        • 4373
                        Originally posted by Austin!
                        And so it begins...
                        Yep! Fuck geometry
                        • tytypetersen
                          • Mar 2012
                          • 347
                          Need a M20b25 flywheel for my 89. i Single Mass.
                          Does it have > 32mm so I can resurface? Good teeth? Would you sell separate from the clutch and pplate?
                          Shipped to 98075?
                          Thanks
