Quick assessment of my car please! M20B25
  • Jboss12
    • 357
    Alright so is this a blown head gasket?
    I have a 1992 BMW 325ic and just did the timing belt, water pump and thermostat. The temp gauge never went past the 1/4 mark. I opened up the thermostat housing only to find it empty. So I put my new Tstat in and the engine temp reads just below the halfway mark.
    Here are the symptoms:
    -coolant looks brown and this is even after I somewhat flushed it out
    -the coolant will sometimes be boiling after a drive (I notice it gargling away once I turn the engine off)
    -sometimes the coolant will come directly out of the expansion tank relief hose and onto the ground
    Other things to note:
    -Car doesn't seem to overheat. It will sort of creep up the halfway when I'm sitting still for a while but never overheats
    -the coolant to water mix is like 20% coolant to 80% water (it's temporary)
    Sound blown? It seems to me like its leaking between the cylinder walls and into the coolant in the engine block. This might be a redundant question but I just figured I'd ask
    Thanks PNW
  • e30austin
    • 15382
    I'd say the brown you see is just rust/corrosion from some numb nuts using just water with no coolant mix. I wouldn't be too concerned. With that said, I would go ahead and run a compression test, if you are that concerned.
    • boostless
      • May 2013
      • 66
      I'd put my money on the cooling system isn't holding pressure or you have air in your system somewhere
      • 2mAn
        SeƱior Mod
        • 20973
        boiling makes me think there is air in the system. hopefully its something simple
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • Jboss12
          • 357
          Thanks for the responses, I appreciate it. Yeah I'm hoping it isn't the head gasket but if it is I guys I can just dive into doing that. I'm becoming familiar with the m20b25 quicker than I thought
          • kylelauffer
            • Dec 2009
            • 624
            check the oil and see if its milky color. if so your getting coolant in the oil and thats a blown head gasket. also how does your exhaust smell and look or can you see any kind of smoke. even a little bit. sounds like cooling system needs some attention first though before making assumptions.
            • Jboss12
              • 357
              The oil looks great, no signs of coolant or yellow rings on the oil cap. The exhaust doesn't produce any visible smoke whatsoever, it does smell a little sweet I guess but it's not anything that noticeable. I'll definitely take care of the cooling system first before I go into anything else
