My 88 325 has recently undergone a bit of maintenance. When I got her back on the road, she was running great. About two weeks ago I noticed a minor stumble. This stumble progressively got worse until now, and its pretty much undriveable.
When I first noticed it, it seemed to start at around 3k rpm and would not be dependent on throttle position.
When it got worse in the following days, it became apparent that it was manageable when cold but got progressively worse as it came to temp, at which point it became horrible.
Then we come to today, where it is now doing this even at cold temps.
When it happens it feels like its coughing or stuttering at light throttle and a very jerky, hardcore stumble at wot. It will hunt at idle which is generally around 1k rpm.
I have recently replaced the following
Tps
Cps
Afm
Injector harness
Throttle body gasket
Fuel pump
Fuel filter
Fpr
All new relays
Cleaned and checked c101
Tested DME
Blower motor resistor
Evap canister thing behind tps under throttle body
Checked grounds and contacts @ battery
Another issue that may or may not be related is that my #10 and #20 fuse keeps blowing and I have no gauges, power mirrors or blower. Aux fan does work tho...
Any help would be very much appreciated as this is my main transportation and I'm stumped.
Whoever finds the problem gets $1 gifted to their paypal.
Thanks guys.
Tps
Cps
Afm
Injector harness
Fuel pump
Fuel filter
Fpr
All new relays
Tested DME
Thanks guys.
