$1 gifted to whoever solves my problem. 325 bucks like a fuckin' horse.
  • Jparkr
    HR Admin
    • Jan 2006
    • 3494
    #31
    Blue colored one is 2 pin for the DME
    Brown colored one is 1 pin for the instrument cluster
    1987 PRO-3 car /1990 325is (2.7i Concours)
    • Savagefurai
      • Apr 2011
      • 970
      #32
      Originally posted by EN318isPDX
      No, one drives the gauge and the other talks to the ECU..
      IIRC sender = ECU and sensor = gauge
      okay, so from what have gathered, the one I want is the two pin sensor and not the single pin sensor.
      Correct?
      Originally posted by Balleristic31
      What brand distributor cap did you get? What brand rotor?
      Stealership brand. Ugh.
      Sent from my SCH-I800 using Tapatalk 2
      Currently without an e30. Will probably die soon.
      • Savagefurai
        • Apr 2011
        • 970
        #33
        Cool. Just picked it up and about to throw it in after some cheap pizza.
        Will let yall know how it goes.
        • Savagefurai
          • Apr 2011
          • 970
          #34
          So I put in the sensor and it hasn't changed a damn thing.
          Starts a little hard, runs fine when cold.
          Pulls hard with no problems till it warms to temp. Then starts with the stuttering and lurching.
          Ugh.
          On to the next thing...
          • LJ851
            • 7919
            #35
            What brand is your new CPS?
            Lorin
            The M30 is God's engine.
            • Tom.
              • Sep 2012
              • 121
              #36
              I just replaced my less than one month old Facet brand CPS with an OEM one and all my issues were solved.
              So, like I'm sure the gentleman above is getting at.. OEM or nothing as far as CPS goes.
              • Savagefurai
                • Apr 2011
                • 970
                #37
                I am actually using the OEM bosch unit.
                • IRON-E
                  • 16548
                  #38
                  +1
                  Paging JLevie
                  @IRON-E30 aka Edwin:D
                  • mrcheezle19
                    • Apr 2012
                    • 1451
                    #39
                    Originally posted by Turf1600
                    Your problem will be solved by buying a new car. Please send me $1.
                    Beat me to it.
                    Dude this is r3v. 20 bucks gets you a used timing belt or a low mileage head gasket
                    • Savagefurai
                      • Apr 2011
                      • 970
                      #40
                      Originally posted by mrcheezle19
                      Beat me to it.
                      Haha. No.
                      Way too broke for that. Plus, I have put too much onto this heap to give up now.
                      • Ryann
                        • 3350
                        #41
                        Symptoms point to a vacuum leak or an AFM issue. Does your MPG needle wig out or CEL illuminate momentarily during the stuttering? I'd also inspect your vibration damper.
                        • Savagefurai
                          • Apr 2011
                          • 970
                          #42
                          Yeah, I am grabbing plug wires and a coil just to be sure and a smoke test is in the future as well.
                          I can't tell if the gauges wig out or not because of the #10 fuse issue.
                          Once I fix that I will let you know about the cel.
                          What points you towards the vibration damper?
                          • QUKBMER
                            • 8178
                            #43
                            Sounds like its time to dump the m20 2.7 for an 24v swap or atleast an m20 2.5 swap bro. Send me $1 please..PM me for paypal thank you.
                            • Jparkr
                              HR Admin
                              • Jan 2006
                              • 3494
                              #44
                              Have you done a compression test with the engine hot?
                              We had a pro3 car with a cracked head, ran great cold... it was mixing coolant but If you had a bad crack that wasn't around a coolant passage it could start making shit go bonkers.
                              It is hard to try and diagnosis shit on R3V you have a list of what you have done, but no way for us to know you didn't screw up something obvious as you have gone.
                              • BigBillions
                                • 123
                                #45
                                car issues
                                hay did you ever get it figured out? its a air leak some were, if not my opinion to check is the afm for leaks actually take it out and do a really good check for pin size holes in the metal part under the afm (its caulked with clear caulking), and the inside of the opening for leaks, the next would be the brake boost lines were they connect to throttle body(both sides of throttle body), shouldn't have to say it but rubber elbow, and the evap hose under the throttle body, also worth checking is the fuel injector seals for leaking, also just to make sure you don't have a leaking head gasket check oil for coolant or a compression test.
