Need S50 help. Car runs but poorly
  • e30austin
    • 15382
    Sounds like you reversed them.
    • Munich Man
      • Jan 2011
      • 516
      Reversed what? The sensors are in correctly. It's a bad ground that I still haven't fixed that's causing the issue for the temp sender. The idle problem is still there, as well as power cutting. Can anyone come look? I will pay!
      • Matt-B
        The Waffler
        • 3856
        No, you might have switched around the harness plugs and have the temp sender for cluster plugged into the ECU sensor
        • e30austin
          • 15382
          This. That would be my guess if it worked before.
          • Munich Man
            • Jan 2011
            • 516
            It didn't work before, but perhaps I've had it backwards from the start? I'll swap them when I get home and post back later. Thanks guys!
            • Matt-B
              The Waffler
              • 3856
              Shoot, might have cam and crank backwards. Not sure how it'd run. Won't hurt to check
              Also check fuel rail ground
              • Munich Man
                • Jan 2011
                • 516
                Well, the main issue (Cutting power while driving) is fixed! Fricken engine to chassis ground.. Anyways, now instead of flopping around my temp sensor moves correctly, but stops right below the quarter way mark. Any ideas? Also still idles a tiny bit rough. Need some advice. Idles low (500-600) and makes random crunching noises.
                • Matt-B
                  The Waffler
                  • 3856
                  I had an alum rad, and other stuff, never moved past 1/4, id replace the gauge in cluster, did you change anything maint. related ? your crappy Idle could be something as simple as spark plugs
                  • Munich Man
                    • Jan 2011
                    • 516
                    It has pretty new plugs on it. Any other ideas for the idle or tach? I'll check the gauge later. Thanks man!
                    • Silvertip
                      • Oct 2012
                      • 329
                      Running cold could be caused by thermostat stuck open.
                      Alpinewhite 318i
                      • Den_k321
                        • 1248
                        as i already told you about your noise : when your timing belt is loose it will cause some drivability issues usually under high load or high rpm. If your timing belt is not properly tensioned it will not keep the valves timed properly to the lower end and this will cause misfires, loss of power, bucking, and could even cause a no start condition.
                        change that tensioner and timing belt since your gonna be there.
                        1988 325is S50 in-progress.
                        http://www.facebook.com/E30LocalCrew
                        Few pictures:
                        http://www.r3vlimited.com/board/showthread.php?t=255061
