E21 help
  • npag206
    • Dec 2012
    • 30
    E21 help
    Hey Guys
    So i have a 79 320i and its a california car. I got it from a buddy for free and I'm trying to get it to run. I removed all the emissions crap and plugged everything up (or so i think). The PO said he replaced the starter but when i go to turn it on I'm getting power everywhere else but nothing is cranking. I would suspect the starter is wired wrong but i have no idea. Any help would be greatly appreciated!! Thanks R3v
  • Nesset
    • Mar 2014
    • 672
    Check the ground to the starter motor. Had the same problem on my 2002... If that is the issue that is.
    -1976 2002 daily (Sold)
    -1986 528e 5 speed daily
    • TobyB
      • 5263
      Make sure it's in neutral and jump the starter wire.
      If it cranks, then it's the switch/wiring.
      If not, check the starter and battery hots and grounds, then suspect the starter itself...
      t
      • FireFight
        • Mar 2012
        • 1367
        just had this issue with my e21.
        there are three wires that go to a e21 m10 starter
        one is from the battery that goes on the terminal closest to the drivers fender
        another goes to the alternator
        and finally there is one that is black with a yellow tracer that goes on the bottom flat spade terminal this on is the one that triggers the starter
        WTB:m60b40 in PNW
        Zachary Ripley
        85 318i M50B25tu.
        92 525it 5 speed.
        80 244gl (m60 prepping).
        • FireFight
          • Mar 2012
          • 1367
          ignition switches are a common failure item on these cars as well
          also check out this thread of mine from when i had this issue after a harness fire
          WTB:m60b40 in PNW
          Zachary Ripley
          85 318i M50B25tu.
          92 525it 5 speed.
          • Twelvizm
            • Oct 2009
            • 2108
            Hit the starter with a hammer.
            • e30austin
              • 15382
              Originally posted by Twelvizm
              Hit the starter with a rubber mallet.
              • SoundByte
                • Jan 2013
                • 335
                Put the car in gear and rock it back & forth.
                • george graves
                  • 19997
                  I use to keep a 1/2" 1' extension in my e21 when the starter would act up. A sold whack, and it would fire right up. Just give the solonoid a good wach, and do not hit the power terminals.
                  Originally posted by Matt-B
                  • Matt-B
                    The Waffler
                    • 3856
                    Check the engine ground. Battery cables. Clean with terminal cleaner, and terminal brush. That has fixed a few "non running" cars of friends etc
                    • npag206
                      • Dec 2012
                      • 30
                      I think I'm missing some grounds. I applied direct power and jumped the T50 terminal on the starter and it cranks. So its either bad grounds or an ignition switch (might run a push button start). Could someone tell me which grounds i need to have in place, i think I'm missing my chassis to block braided strap...thanks
                      • Jrssampson
                        • Mar 2014
                        • 109
                        Check the ignition fluid
                        • 4tDX
                          • Jul 2014
                          • 509
                          I just had a similar no crank issue on my E30:
                          It ended up being a grounding issue, but my car would not crank when I jumped to terminal 50... So, in your case I would also check to see if the small wire running to terminal 50 on the starter solenoid is receiving ~12 volts when you turn the key to the START position. However, the grounding straps are very important so I would definitely get an oil pan / engine block ground strap if it is missing.
                          If you are not seeing ~12V, like the others said, i would check the (1) relays, (2) fuses, and (3) ignition switch for continuity in the various positions ("OFF", "ON", and "START").
