UPDATE: Timing Belt Snapped. Car broke down, downtown kirkland
  • tonyloban
    • Oct 2013
    • 254
    Was cruising really slow in downtown kirkland and the car died. I was lowish on fuel but my dad brought about 3 gallons and it's still not starting. If it was my timing belt (which is due) I would hear it, right? My dad and I think it's either that or the fuel pump.
    My Photography - http://www.flickr.com/photos/106236166@N06/ - My Photography
  • SketchyRex
    • Feb 2012
    • 242
    Do you hear the pump turn on once the key is in the on position?
    • 5Toes
      • 9836
      main relay????
      • tonyloban
        • Oct 2013
        • 254
        Where is the pump located? What does it sound like?
        My dad tried listening for it but it's pretty loud here in downtown. And we're not exactly e30 geniuses.
        • tonyloban
          • Oct 2013
          • 254
          When you turn the key, the starter spins perfectly, but we looked in the engine through the oil cap hole and nothing is turning in there. Is that normal?
          • SketchyRex
            • Feb 2012
            • 242
            The first pump is located in the tank. Just under the seat on the passenger side in the rear.
            The other pump is located underneath the car on the drivers side towards the rear tire.
            • tonyloban
              • Oct 2013
              • 254
              I don't hear anything coming from there right now. If someone knows if stuff is supposed to be moving in the engine while the starter is spinning, that would help. I really hope it's the fuel pump.
              • Stanley Rockafella
                • Aug 2011
                • 4062
                do you mean the engine is turning over (cranking)?
                the second part of that post isnt' good, esp if the engine was actually cranking over (starter sounds like it usually does when starting car)
                • tonyloban
                  • Oct 2013
                  • 254
                  It's a higher pitched noise, which I assume to be the starter. The engine is not turning over
                  • e30austin
                    • 15382
                    If it just goes "WHEEEEEEEEEEEEEEERRRRRRRR", you lost the belt.
                    • tonyloban
                      • Oct 2013
                      • 254
                      I think it's the belt. The engine doesn't turn over for sure. Uuuuuuuggggggggghhhhhhhh
                      • FireFight
                        • Mar 2012
                        • 1367
                        take a socket to the crank pully and turn it will you have the oil fill cap open, have someone look inside, if you see the rockers move as they should your belt is fine
                        WTB:m60b40 in PNW
                        Zachary Ripley
                        85 318i M50B25tu.
                        92 525it 5 speed.
                        80 244gl (m60 prepping).
                        • 4tDX
                          • Jul 2014
                          • 509
                          If the crankshaft is turning without a belt wouldn't it be pretty apparent that a couple of the pistons and valves are interfering; noise, broken rockers, etc?
                          When you run the starter does it actually sound like its turning over the engine; does it sound like it always has? Or has the noise changed, like a higher frequency noise?
                          • Rennsport
                            • 2139
                            If its just a high pitch noise and doesn't sound like any part of the engine is turning, it would be the solenoid on the starter is bad.
                            m106 1990 e30
                            e36 daily
                            e32 cruiser
                            • tonyloban
                              • Oct 2013
                              • 254
                              Would a video help? I don't think the engine is turning over. When i
                              The car died, I was rolling like 5mph, heard a click, and then dead. The click wasn't very loud, just the last thing I heard.
