E30 and compatible Diffs for Dummies?
  • delamaize
    • Nov 2013
    • 1462
    OK, so I am at work, and for some reason, the search feature doesn't work on this computer. can anyone point me in the direction of a thread that talks about diffs, ratios, E30 compatible diffs, and such. I'm starting to research and look for a diff for the M60 build, I want to start on my rear subframe soon....
    Dumpster Fire Pilot
  • Rennsport
    • 2139
    Here's pretty much all you need to know about diffs:
    m106 1990 e30
    e36 daily
    e32 cruiser
    • djjerme
      • 5082
      Short answer:
      Diffs that will fit an E30 with little to no modification:
      E36 318ti
      Z3
      The ratio's available are all across the board. There are two different size cases that were used in the E30's so be aware when you are looking at an "E30" diff.
      With that in mind, you can swap the internals from many different non-E30 cases in to an E30 case as long as it's the same center section.
      For example, on our PRO3 cars we are using 1.9 Z3 diffs (4.27 ratio) with LSD's robbed from other E30 and a couple E36 LSD diffs. The interal dimension are the same, you just need to check the pinion depth and pattern once you get it back together.
      Like I said, over simplified, but will get you the basics to go on.
      2016 Ford Flex
      • delamaize
        • Nov 2013
        • 1462
        Thanks guys, I'm going to get reading on that first link.
        I'm begining to think I may have to assemble a LSD myself to get what I want. I have a '87 Eta right now, so I think it's a 2.93 open. But with the M60 + Getreg 420g swap, I think that I'm going to need between a 3.10 and 3.30 ratio to keep the revs where I want it. So that leaves me with the 3.15, 3.23 and 3.25, which from what I understand, are all pretty much unicorns.....
        Dumpster Fire Pilot
        • ajhostetter
          • Apr 2013
          • 1218
          What kind of budget are you working with? Haoming (Wanganstyle) on here builds nice diffs. I think I paid ~$1100 for a 3.15 torsen. A clutch type diff would've been ~$1500.00.
          2014 GTI | 2002 Land Cruiser | 1991 Volvo 745t
          • delamaize
            • Nov 2013
            • 1462
            Yeah, as awesome it would be, I don't have the budget to drop $1000 on a diff.
            Dumpster Fire Pilot
