My DIY vinyl wrap
  • trinidee247
    • Sep 2009
    • 10
    How did the sunroof turn out?
    Sent from my SGH-T999V using Tapatalk
    • mcdougal
      • Nov 2014
      • 251
      It's in one of the pictures above. It looks ok but I found that it's basically impossible to take the seal off and on so I just ran the vinyl to the edge of the trim and cut it. Would look cleaner if I was able to wrap down around the edges and then pull the seal over but oh well.
      • Ether-D
        • Sep 2011
        • 2838
        Originally posted by Andy.B
        Awesome work! I like the color, and the seams look like they blend in well.
        The more wrap success stories I see, the more I think I am going to try this next time I need bodywork done.
        Right?!
        That really does look good McD. Especially when compared to what a first time DIY paint job could look like (and cost).
        I was born on 3/25…
        • willworkfore30s
          • Aug 2011
          • 1090
          Looking good. All the photos from when I wrapped mine are in this album. I'm certainly not a pro but to do an e30 with no seams would waste a ton of vinyl. I made mine in similar places to yours it looks like. If you make the overlap small, the seems pretty much disappear.
          A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
          • CENTURION
            • May 2015
            • 372
            Looks Great to me!
            where can you find good quality vinyl online?
            • mcdougal
              • Nov 2014
              • 251
              Originally posted by CENTURION
              Looks Great to me!
              I ordered vvivid vinyl because it was about half the cost of 3m. It remains to be seen if it's good quality or not.
              • CENTURION
                • May 2015
                • 372
                I hope they have something close to bronzit. I'll check it out, thanks
                • 968Reckless
                  • May 2013
                  • 1095
                  I would just go 3m...you get what you pay for and I've used other brands. 3m is the best and easiest to install hands down.
                  /// MTech Belts ///
                  S52 BUILD
                  M3 VERT BUILD
                  • 968Reckless
                    • May 2013
                    • 1095
                    I had no problem removing my sunroof. Any time you just cut the edge it will eventually become a problem and peel back...
                    /// MTech Belts ///
                    S52 BUILD
                    M3 VERT BUILD
                    • DeM3n
                      • Mar 2005
                      • 1260
                      Looks good man. I've wrapped interiors before and it can be a tedious job so I can appreciate the work you've put into this.
                      • mcdougal
                        • Nov 2014
                        • 251
                        • mcdougal
                          • Nov 2014
                          • 251
                          All done other than the front trim piece
                          • Reichart12
                            • Aug 2012
                            • 2165
                            Looks good. When you finish how many hours do you think you would have in the wrap job?
                            Instagram: Reichart12
                            • mcdougal
                              • Nov 2014
                              • 251
                              Probably around 25. If I were to do it again it would take 15 or so.
                              • djjerme
                                • 5082
                                Looks good.
                                Vinyl wrapping is one of those things you shouldn't rush. So I don't recommend it to a newbie who can't devote some serious blocks of time to just relax and get in to it. IF you can afford the time, the reward is good results like the OP!
                                2016 Ford Flex
