FS: 1988 325iX Lachs/Cardinal
  • cg138
    • 589
    For sale is a two door, 1988 BMW 325iX. It has a Lachssilber (Salmon Silver) exterior and a Cardinal Red interior. The car currently has ~207.5k miles; mileage will continue to go up slowly as it gets driven. I have really enjoyed this car for the past 4.5 years, but it’s time for me to move onto something else. The car is by no means perfect, it is a 28 year old driver; but it has never left me stranded. I will try to list out what I remember about the car as well as some of the recent repairs.
    General info:
    5-speed manual transmission
    Build month: October 1987
    Clean WA State title in hand
    I have had zero issues with annual registration. The car is emissions-exempt in Washington (older than 25 years), but it passed with flying colors at the last emissions test ~2 years ago.
    Car will be eligible for Washington Collector Vehicle status in <2 years
    Car started life in New York, then went to Pennsylvania, before coming out to Washington
    Original owner’s manual and two sets of keys will come with the car
    The few modifications made to this car:
    Z3 1.9 shifter (shortens throws) with leather ZHP shift knob
    Bilstein shocks and H&R Sport springs installed by previous owner
    Magnaflow exhaust
    Pioneer speakers and head unit with CD, USB and Aux In capabilities
    Aftermarket remote keyless entry and alarm
    173 DME ECU installed in lieu of 153 DME ECU. 173 ECU includes updated OBD stomp tests and updated engine mapping. Original VIN matching 153 DME ECU will come with the car
    Leather E36 handbrake grip. Original E30 plastic grip will come with the car
    14 inch steelie spare tire upgraded to 15 inch spare tire on iX basketweaves. Original 14 inch steelie spare wheel will come with the car
    The Good:
    All panels are VIN number-matching
    Functional AWD
    Cardinal Red interior is factory; it was not swapped in at a later time
    Clean interior. A small dime sized rip on the driver’s seat bolster of the bottom cushion. Otherwise no other rips.
    Factory cardinal red floor mats included, but driver’s mat is beat up. Cardinal Red floor mats are no longer available (NLA) from BMW.
    Clean, non-sagging headliner
    Uncracked dash
    Both front seats have functional tilting mechanisms
    No leakage into the interior. All door seals, sunroof seals and trunk seals seal
    Power sunroof opens and closes (tilt and sliding).
    Functional interior and exterior lights except for side marker lights
    Fully functional OBC, including exterior temperature sensor, except lightbar has gone out
    Fully functional check panel
    Has rear pop out windows
    Functional central locking system. Driver’s side door lock is a little tight to turn, but will lock and unlock, as well as actuate the double lock feature.
    Fully extending and retracting power antenna
    Complete set of trunk tools, including plastic manual window crank
    Oil change and oil filter change every 3,000 miles with conventional, non-synthetic 10W-40 oil
    All 4 wheels include wheel center
    Spare wheel and tire updated to match the rest of the iX weaves. Spare tire is new and has not been used from ~3 years/25k miles ago
    Straight front and rear valence
    The Not So Good:
    Paint is fading. Rear trunk lid and rear quarter panel right above the fuel filler door is the worse. Could use a repaint
    Few minor door dings on body.
    Scratch on the passenger side plastic iX rear wheel arch flares
    Foot-long scratch on driver’s side door. I think someone keyed the car years ago.
    Side marker lights are not functional. Some of the corners work with a new bulb and cleaning of the contact leads
    Cracked glass on headlights and foglights. Though they are original and are all functional.
    Headlight adjustment screws are rusted and don’t adjust.
    There is a rust spot on the passenger side of the rear apron underneath the rear tow hook.
    The front passenger side bumper has been pushed in due to a guy backing into me. I have been driving the car like this for the past 4+ years, and it does not impact drivability at all.
    Sunroof seal is worn but still functions fine. I have a replacement OE sunroof seal that will come with the car.
    AC compressor functional, but does not actually produce cold air, system will probably need recharge of refrigerant. AC system is original; it is NOT converted to R134a
    Engine will eventually need a rebuild. Compression is ok, but leak down on a couple of cylinders are not so good.
    Exhaust header heat shield is rotted through. A replacement set is included with the car.
    Car burns about a quart of oil every ~2,500 miles
    O2 sensor should be replaced. The threads on the sensor has rusted through, making removal difficult; it may be easier to just replace the entire exhaust from another car when it has to be off for the exhaust header heat shields to be replaced anyway.
    Driver’s side trim piece behind the rear pop-out window is missing
    Cruise control not functional
    Front and rear brake pad wear sensor needs replacement. Front sensor wires are damaged and will need to be spliced
    The It Is What It Is:
    Car did not come with heated seats, and this is the only option that the car does not have.
    Car does not have folding rear seats, folding rear arm rest or ski pass-through.
    Recent Notable Repairs. All repairs using OE or OEM parts unless otherwise noted:
    Brake hard lines and iX brake booster replaced at ~201k miles
    Intake coolant bypass gasket and intake hoses replaced at ~195k miles
    Trunk seal replaced at ~192k miles
    Odometer gears replaced with Garagistic gears at ~191k miles
    Front inside CV boots replaced at ~190k miles
    Heater core replaced at ~185k miles
    Inspection II completed at ~180k miles
    Timing belt, water pump and thermostat replaced at ~180k miles
    Brake master and slave cylinders replaced at ~175k miles
    Rear wheel bearings replaced at ~170k miles
    Timesert installed on oil pan at drain hole at ~165k miles
    Car is located in Seattle, WA. I will not be shipping the car anywhere. I’m happy to work with non-local potential buyers, but the buyer will have to meet me in the Greater Seattle area to finalize the deal and pick up the car.
    Asking $3,500 OBO.
    Pictures (in various states of cleanliness from the past):
    1988 BMW 325iX - Lachssilber/Cardinal - Gone
    2001 BMW M5 - Anthracite/Black Heritage
    1999 Toyota 4Runner - White/Oak
  • e30austin
    • 15382
    Sad to see it go, Cheuk-Hung. Best of luck to you on whatever is going on in your life.
    • DrJosh
      • 2011
      Good luck!
      Originally posted by Sonny
      I am a meme for our community.
      • TheDestroyer
        • Sep 2013
        • 22
        If I had money I would be all over this
        Sent from my SM-G928V using Tapatalk
        • spiDmang
          • 3941
          Damn Cheuk :( sad to see it leave, but at least we can still get drunk in Leavenworth :up:
          If this is still available in the next couple weeks (which I doubt), we will be in contact
          91' 318iS - S54/6MT Swapped
          08' E90 M3 6MT - Daily
          Originally posted by IronJoe
          Originally posted by 2mAn
          • 2mAn
            SeƱior Mod
            • 21093
            GLWS Cheuk, I am trying to figure out a reason to pick up an iX in the city that never rains lol
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            Make R3V Great Again -2020
            • cg138
              • 589
              Thanks all for your kind words. I've learned a ton and met some really great people in this community. We'll see what happens, and no matter what, I'm sure I'll still be seeing you around.
              • cg138
                • 589
                Still available.
                • cg138
                  • 589
                  Bump
                  • 2mAn
                    SeƱior Mod
                    • 21093
                    Bump
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
                    • ST1G
                      • Oct 2012
                      • 6690
                      PM'd
                      • cg138
                        • 589
                        Thanks all for your interest. This car is no longer available.
