Bleeding the brakes help?
  • Den_k321
    • 1248
    Hey guys, wondering if any of you have the power bleeder and skills to bleed the brakes? I give up haha (changed my master+slave clutch cylinders, while was there put stainless brake lines, now having hard time bleeding my brakes..)
    Let me know if someone available some evening to help...
    425-350-6766
    1988 325is S50 in-progress.
    http://www.facebook.com/E30LocalCrew
    Few pictures:
    http://www.r3vlimited.com/board/showthread.php?t=255061
  • BraveUlysses
    • Jun 2007
    • 3781
    how have you trying to bleed them? A pressure bleeder helps but isn't necessary.
    i might be able to help over the weekend
    • Den_k321
      • 1248
      Open, pump 7-10times, close , pump few times, starting with far side..
      Few pictures:
      • BraveUlysses
        • Jun 2007
        • 3781
        hmm. do you have a catch container and hose? it makes it much easier to prevent air bubbles from sneaking back into the valve. see this video for an example of the catch container.
        try this:
        pump brake/clutch pedal till it's firm
        open
        pump 2-3 times
        close
        pump 2-3 times until pedal is firm
        open
        pump 2-3 times
        close
        open
        pump 2-3 times
        close
        check fluid reservoir and examine the hose to see if you've flushed out all the bad fluid and bubbles.
        move to next wheel
        it sucks doing this by yourself btw. having someone who is operating the wrench on the valve can tell you when the fluid is clean and its no longer pushing out air bubbles.
        • spiDmang
          • 3941
          ninja edit.
          yeah, follow Kris's advice. Thats what i do as well
          91' 318iS - S54/6MT Swapped
          08' E90 M3 6MT - Daily
          Originally posted by IronJoe
          Originally posted by 2mAn
          • TimeMachinE30
            • Jun 2014
            • 3749
            If you like to tinker with cars, the Motul Power Bleeder kit was a great purchase. I got mine from ECS Tuning I believe with the best price.
            It makes bleeding a single man job, a real cinch. Sub $100.
            Or a good buddy can help, too.
            ACS S3 Build / Dinan 5 E34
            • e30austin
              • 15382
              Pumping will create lots of bubbles and make bleeding more difficult. Buy a power bleeder and be done.
              • Matt-B
                The Waffler
                • 3856
                One trick you can use, buy a pistol oiler, open bleeder, pump fluid from caliper to res, turkey baste excess out.
                I use this on clutch also
                • Yungbimmer
                  • Jun 2015
                  • 97
                  You need a hose (clear so you can see the air bubbles and new fluid) to put over the bleeder valve so the bleeder doesn't suck air back in.
                  Start with the wheel farthest from the MC, so the passenger rear wheel.
                  Put the hose over the bleeder, open valve, and have your friend pump the pedal 12 times.
                  On the 12th pump have them hold the pedal down then close the valve.
                  Repeat for all wheels in the order of:
                  Passenger rear
                  Driver rear
                  Passenger front
                  Driver front
                  Make sure to check the fluid reservoir and add fluid after every wheel so you dont starve the lines.
                  As for the clutch.
                  Put the hose on the bleeder vlave, open the valve and have your friend pump the clutch until you see fresh fluid coming through the hose. Have your friend hold down on the pedal and close the valve, then they can let off.
                  Keep in mind that no matter how many times you pump the clutch it will stay on the floor, this is supposed to happen.
                  All you have to do from there is simply keep pumping the clutch up and down until it regains pressure.
                  Thats how I've always done it and it never gave me problems.
                  One question though. Did you wet (fill with fluid) the cylinders before install? Doing so will make it easier to bleed after install. Hope this helps OP!! Good luck, man!
                  • djjerme
                    • 5082
                    Bleeding brakes - one of my least favorite things to do on ANY car.
                    Seriously, I know it's simple with a pressure bleeder, but I still hate it.
                    2016 Ford Flex
                    • TimeMachinE30
                      • Jun 2014
                      • 3749
                      With a pressure bleeder, it is a snap. What is not to love?!
                      • TobyB
                        • 5296
                        Even with the hose, air gets sucked back in through the threads of the bleeder.
                        2 people, one in the car.
                        Put pressure on the pedal, open bleeder. fluid comes out. close bleeder. Release pedal.
                        repeat.
                        t
                        • e30austin
                          • 15382
                          repeat.
                          t
                          This. It's not a difficult concept.......
                          • djjerme
                            • 5082
                            Neither is scooping up dog poop in the backyard. Doesn't mean I enjoy doing it..
                            Sent from my 710C using Tapatalk
                            2016 Ford Flex
                            • Den_k321
                              • 1248
                              Just tried that, and fluid comes out without bubbles, started with the far side.
                              Both rears, the fluid seems to come out much more, front both much less but steady with no bubbles...
                              After that i pump few times, brake paddle feels pretty firm, then as soon as i start the car it becomes super light and brakes dont work much... if i press really fast it feels like it would get harder and car almost chokes...
                              brake booster? but it pumps fluid thru?
                              I will buy power bleeder, just thought someone close by have one...
                              try this:
                              open
                              pump 2-3 times
                              close
                              open
                              pump 2-3 times
                              close
                              open
                              pump 2-3 times
                              close
                              move to next wheel
                              Few pictures:
