E30 starter removal
  • Munich Man
    • Jan 2011
    • 515
    E30 starter removal
    So fed up with this thing I'll give someone $25 and some food to drop the starter for me. In the middle of a 5-speed swap I'm wasting too much damn time trying to get it out. Located in Mukilteo.
    Car is a 1991 325i
  • e30austin
    • 15382
    Extensions and a universal joint are your friend. Power tools are helpful, too.
    • FireFight
      • Mar 2012
      • 1367
      pull the motor, so much easier! you can have then engine out in a couple hours and will save you a shit ton of headache.
      WTB:m60b40 in PNW
      Zachary Ripley
      85 318i M50B25tu.
      92 525it 5 speed.
      80 244gl (m60 prepping).
      • FireFight
        • Mar 2012
        • 1367
        and weld that nut to the starter to save the headache later down the road
        WTB:m60b40 in PNW
        Zachary Ripley
        85 318i M50B25tu.
        92 525it 5 speed.
        • DeM3n
          • Mar 2005
          • 1260
          I came at mine from the front. Had someone holding the bolts in place under the car and used extensions to come at it. Worked for me and maybe worth a shot.
          • 4tDX
            • Jul 2014
            • 509
            I don't know why, but this seemed infinitely harder on my late model car. More stuff in the way?
            I removed the intake and weaved some extensions to the starter nuts on the engine side. Then from under the car I was able to put a 2nd ratchet on the torx bolt to hold it in place. With my other hand I could easily reach up into the engine bay to get access to the ratchet on the bolt/engine side.
            I ended up using about 1.5ft of extensions and this placed the ratchet just behind the alternator.
